Rusty Tub |
Rusty Tub |
Hammer920 |
Jun 28 2005, 03:39 PM
It's a Learning Experience Group: Members Posts: 83 Joined: 27-April 04 From: Levelland, TX Member No.: 1,989 |
I took the fire wall back pad off yesterday found
more holes so took the seats amd carpet of this is what i found besides $1.07 in change. how bad does this look and the wireing there was 3 wires that was cut that has to be the A/C wireing the wireing in the back the red and black is to the fule pump and the bare one w solder on top, is the other to pump which is surrounded inside the wireing harness Brown. Hope these pic's post. The engine is ready to go back in but not in this tub like it is. http://porsche914.togapc.com/6-28-05/DSCF0009.jpg http://porsche914.togapc.com/6-28-05/DSCF0010.jpg http://porsche914.togapc.com/6-28-05/DSCF0011.jpg http://porsche914.togapc.com/6-28-05/DSCF0012.jpg http://porsche914.togapc.com/6-28-05/DSCF0018.jpg http://porsche914.togapc.com/6-28-05/DSCF0025.jpg http://porsche914.togapc.com/6-28-05/DSCF0026.jpg http://porsche914.togapc.com/6-28-05/DSCF0028.jpg |
tat2dphreak |
Jun 28 2005, 03:43 PM
how are the longs? hell hole?
because that firewall is fixable... I think you can still get a repro of the whole damn thing! |
xsboost90 |
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
looks pretty crusty. Cut until the rust is gone, weld until the holes are gone. Get an old hood/door or something and use that to fill in the holes....or buy the panel but.. (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif)
lapuwali |
Jun 28 2005, 03:50 PM
You can see air through the suspension console through one of those holes. That looks pretty bad. Not unfixable, but it will take a lot of work to revive that car. Here in CA, that's a parts car.
jet1 |
Jun 28 2005, 03:53 PM
Member Group: Members Posts: 311 Joined: 16-June 04 From: Accord,NY Member No.: 2,213 Region Association: North East States |
Take up all the tar floor covering with a heat gun. then you will be able to see how bad the floor is and you will have a better idea of the extent of the rust.
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) Hell hole, longs and suspension console are the important areas as far as rust goes |
TravisNeff |
Jun 28 2005, 04:01 PM
a little cutting and welding for sure. You'll have to fab the replacement pieces - they don't sell that upper firewall piece as far as I know. Check the hell hole on either side, you may have to do some work there as well, unless this is from a wet sound deadening pad.
MattR |
Jun 28 2005, 04:09 PM
You're not the only one (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
(IMG:http://www.914world.com/bbs2/uploads/blog-1109827817.jpg) imagine the coincidence... a signal orange 73 with a dark blue respray with rust in the same place. (IMG:http://www.914world.com/bbs2/uploads/blog-1109828667.jpg) (thats primer in the engine bay) Stick with it though. Mine's all cleaned up now and awaiting reassembly (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) (IMG:http://www.914world.com/bbs2/uploads/blog-1119242956.jpg) |
Hammer920 |
Jun 28 2005, 05:57 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) yup gonna do a lot of cuting and grinding cont find 20 gage plate will have to go with 22 gage but longs are good chop chop here chop chop there.... (IMG:http://www.914world.com/bbs2/html/emoticons/sawzall-smiley.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/sawzall-smiley.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/sawzall-smiley.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif)
Hammer920 |
Jun 28 2005, 06:12 PM
wet sound pad probly so not going back with it but the floors will gget heat gunned and see how bad it really is....
SpecialK |
Jun 28 2005, 06:46 PM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
I feel your pain Richard.... (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
Found this when I went to install the new carpet. Seatbelt attach bolt.....wasn't (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) . Glad I didn't need them in the 500 miles I put on it prior. (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) Good luck my friend, everything's fixable. Just depends on how much time and effort you want to invest. (see Michelko's "Diggin' into Hell" thread) Attached image(s) |
Hammer920 |
Jun 28 2005, 07:09 PM
the rust i have is not that low hell hole under the battery bottom right goes through the side not the frame can grind that down and weld new plate on top. I have not dropped the rocker panels yet but I do know that the jack post on the drivers side is just dangleing will drop that friday when i am off......22-24 gage plate weldable steel is as close as i can find in Levelland or Lubbock probly going with 22 gage to weld it back, never mig welded have arch welded and welded the muffler mounts on the SS heat exchangers that I Have Will Post pic's of the engine totaly back togeather when I can get my dig camera back this weekend. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
tat2dphreak |
Jun 28 2005, 09:07 PM
don't sweat the MIG... it's 100 X easier than stick... none of that hammer and brush SHIT!
Hammer920 |
Jun 28 2005, 09:27 PM
here some more pics will use eivlbay for interior parts....
http://porsche914.togapc.com/6-28-05/DSCF0007.jpg http://porsche914.togapc.com/6-28-05/DSCF0013.jpg http://porsche914.togapc.com/6-28-05/DSCF0014.jpg http://porsche914.togapc.com/6-28-05/DSCF0015.jpg http://porsche914.togapc.com/6-28-05/DSCF0016.jpg http://porsche914.togapc.com/6-28-05/DSCF0017.jpg http://porsche914.togapc.com/6-28-05/DSCF0019.jpg http://porsche914.togapc.com/6-28-05/DSCF0020.jpg http://porsche914.togapc.com/6-28-05/DSCF0021.jpg http://porsche914.togapc.com/6-28-05/DSCF0022.jpg http://porsche914.togapc.com/6-28-05/DSCF0023.jpg http://porsche914.togapc.com/6-28-05/DSCF0027.jpg |
Lo-Fi Version | Time is now: 19th May 2024 - 07:41 PM |
