Unable to operate passenger window, How to tighten clamp on actuator? |
HansJan |
Aug 19 2019, 10:18 PM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
Hello,
The passenger side window is having issues. With new seals in place the door window needs to be pulled down. However when doing this (turning window crank Counter Clockwise), the actuator goes down but the glass does not follow. Untill it suddenly does (and then it just falls down). The clamp, that holds the bottom of the glass, seems not thight enough. I treid to glue it in. But that didn't work. How to resolve this? See pics. |
Mikey914 |
Aug 19 2019, 11:09 PM
The rubber man Group: Members Posts: 12,657 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Scrape with a razor blade, clean thoroughly with rag and acetone then use 5 min epoxy to set it. looks like you tried, but it either had oil on it or the mix ratio was off
Lo-Fi Version | Time is now: 8th May 2024 - 02:31 AM |
