Major Cooling System issues, Flap system removed by PO |
Gatornapper |
Aug 20 2019, 09:29 AM
Senior Member Group: Members Posts: 1,215 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
Need the Brain Trust help again - big time.
Up to now, nothing I've faced in getting this sweet 14 running and back on the road has been major or disheartening. Lots of new stuff, running pretty good but not perfect, etc. That just changed. Ever since getting the engine running a few months ago, I was concerned that it took a long time to warm up. My first 1 hour + drive was last week - and temps got too high for my comfort - about 1/4" from red line. So I've been drilling down on that issue. For one thing, car sat in a barn (new one) for 12 years - so I wondered about mice nests above the cylinders from the day I bought the car. Yesterday with my scope I found, yes, they are there between the cylinders - at least between 2 & 4. I think I can get them out with a small vacuum through the spark plug holes in the top tins.....we'll see. Due to total ignorance of 914's and VW engines, I know nothing of the air ducting system, but in the learning process, and thanks to anderssj , I find the whole flap/door system and its controls are missing. Gone. So I can only assume that the PO removed them due to problems with overheating. Stupid move for sure. I have to correct that. I understand that move itself could cause overheating. I dread pulling the carbs, intake manifolds, distributor and other stuff to get the top tins off. Plan is to see if I can get the mouse stuff off the cylinders with a small vacuum, make sure all is clean with my scope. If successful, I'll then drive the car and see if it still gets too hot. If I can't get the debris removed with vacuum, I know I have to pull the top tins. But I am told that not having the flap system itself could cause overheating. So I have to get that system installed and working. Yes, I know the many potential causes of overheating like improper timing, plugs, etc. Timing good, plugs good - new. Valves adjusted by dealer about 1,500 miles ago. Got a lot of work ahead - all when I wanted to have the car ready for the big PCA 9/14 914 Vintage Drive. Any help and advice is of course, as always, appreciated. GN |
Gatornapper |
Aug 21 2019, 05:33 AM
Superhawk -
Was MY BAD, not the dealer who checked the compression in 2005 and 4k miles ago. Don't know of car setting at all when he checked it. Car sat in barn for 12 years - I thought of the possibility of a nest, but thought I'd just be careful watching temp. In many drives of 30 min or less, car never even reached operating temp. Over a dozen drives. So I figured no problem. No nest, right? I had no idea flaps had been removed preventing normal warm up. So then last Friday I took the car for its first long drive. No problem for first hour or so. Then got on interstate, and watched it go high - but never reach the red......If it touched the red, I was pulling over and shutting down. And I was too far from home to just pull over and let it cool since it wasn't in the red. So it was my doing the damage from not understanding the system. MY BAD! But 90/100 isn't good compression anyway, so a rebuild has always been a known possibility. GN |
Lo-Fi Version | Time is now: 19th May 2024 - 08:35 PM |
