Major Cooling System issues, Flap system removed by PO |
Gatornapper |
Aug 20 2019, 09:29 AM
Senior Member Group: Members Posts: 1,232 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
Need the Brain Trust help again - big time.
Up to now, nothing I've faced in getting this sweet 14 running and back on the road has been major or disheartening. Lots of new stuff, running pretty good but not perfect, etc. That just changed. Ever since getting the engine running a few months ago, I was concerned that it took a long time to warm up. My first 1 hour + drive was last week - and temps got too high for my comfort - about 1/4" from red line. So I've been drilling down on that issue. For one thing, car sat in a barn (new one) for 12 years - so I wondered about mice nests above the cylinders from the day I bought the car. Yesterday with my scope I found, yes, they are there between the cylinders - at least between 2 & 4. I think I can get them out with a small vacuum through the spark plug holes in the top tins.....we'll see. Due to total ignorance of 914's and VW engines, I know nothing of the air ducting system, but in the learning process, and thanks to anderssj , I find the whole flap/door system and its controls are missing. Gone. So I can only assume that the PO removed them due to problems with overheating. Stupid move for sure. I have to correct that. I understand that move itself could cause overheating. I dread pulling the carbs, intake manifolds, distributor and other stuff to get the top tins off. Plan is to see if I can get the mouse stuff off the cylinders with a small vacuum, make sure all is clean with my scope. If successful, I'll then drive the car and see if it still gets too hot. If I can't get the debris removed with vacuum, I know I have to pull the top tins. But I am told that not having the flap system itself could cause overheating. So I have to get that system installed and working. Yes, I know the many potential causes of overheating like improper timing, plugs, etc. Timing good, plugs good - new. Valves adjusted by dealer about 1,500 miles ago. Got a lot of work ahead - all when I wanted to have the car ready for the big PCA 9/14 914 Vintage Drive. Any help and advice is of course, as always, appreciated. GN |
rhodyguy |
Aug 23 2019, 01:14 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
I think you're getting ahead of yourself. You know the cooling flaps, bellow and wire need to be installed. You'll see if the oil cooler needs to be addressed when you get the tin off. If you scope it and it's fouled you're right back to square one. Trying to squirt brake cleaner on the cooler as it sits is a waste of time and money. The stench will be massive after a couple of cans.
Gatornapper |
Aug 23 2019, 06:29 PM
Rhodyguy -
You are right on. So, can I install the flaps, bellow and wire from up top? Do I just take off the front tins? Bellow/thermostat goes below, right? Having never seen one, I don't know - Haynes manual is clear as mud. Where can I find all I need for the flaps, etc.? All the parts? So I am focused on putting the flaps in next. But I need all the help I can get - I am the greenest of green on all things 914. And I don't have another one nearby to check out....that I know of. Appreciate all the help....... GN I think you're getting ahead of yourself. You know the cooling flaps, bellow and wire need to be installed. You'll see if the oil cooler needs to be addressed when you get the tin off. If you scope it and it's fouled you're right back to square one. Trying to squirt brake cleaner on the cooler as it sits is a waste of time and money. The stench will be massive after a couple of cans. |
Lo-Fi Version | Time is now: 29th May 2024 - 09:13 PM |
