Major Cooling System issues, Flap system removed by PO |
Gatornapper |
Aug 20 2019, 09:29 AM
Senior Member Group: Members Posts: 1,215 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
Need the Brain Trust help again - big time.
Up to now, nothing I've faced in getting this sweet 14 running and back on the road has been major or disheartening. Lots of new stuff, running pretty good but not perfect, etc. That just changed. Ever since getting the engine running a few months ago, I was concerned that it took a long time to warm up. My first 1 hour + drive was last week - and temps got too high for my comfort - about 1/4" from red line. So I've been drilling down on that issue. For one thing, car sat in a barn (new one) for 12 years - so I wondered about mice nests above the cylinders from the day I bought the car. Yesterday with my scope I found, yes, they are there between the cylinders - at least between 2 & 4. I think I can get them out with a small vacuum through the spark plug holes in the top tins.....we'll see. Due to total ignorance of 914's and VW engines, I know nothing of the air ducting system, but in the learning process, and thanks to anderssj , I find the whole flap/door system and its controls are missing. Gone. So I can only assume that the PO removed them due to problems with overheating. Stupid move for sure. I have to correct that. I understand that move itself could cause overheating. I dread pulling the carbs, intake manifolds, distributor and other stuff to get the top tins off. Plan is to see if I can get the mouse stuff off the cylinders with a small vacuum, make sure all is clean with my scope. If successful, I'll then drive the car and see if it still gets too hot. If I can't get the debris removed with vacuum, I know I have to pull the top tins. But I am told that not having the flap system itself could cause overheating. So I have to get that system installed and working. Yes, I know the many potential causes of overheating like improper timing, plugs, etc. Timing good, plugs good - new. Valves adjusted by dealer about 1,500 miles ago. Got a lot of work ahead - all when I wanted to have the car ready for the big PCA 9/14 914 Vintage Drive. Any help and advice is of course, as always, appreciated. GN |
Gatornapper |
Aug 24 2019, 09:51 AM
FYI - dropping the engine is no problem in and of itself.
What is the problem is that my lift bay is in demand for other work and vehicles and if it is going to be tied up for any period of time, I need to plan that well in advance. Dropping the engine will tie up my lift bay for some time, as I am involved in 100 other things besides working on my 914......actually, working on it is something I do in my spare time......and because of that I don't know how long it will take me to do the work with the flaps. I also don't want to drop the engine twice in a short period of time. It needs a top-end rebuild and I need to plan that out. I'm still not certain of which way I want to go on that. Hopes this helps to explain some of my comments......the problem and issue is timing, not technicals....... GN |
Rand |
Aug 24 2019, 09:56 AM
FYI - dropping the engine is no problem in and of itself. What is the problem is that my lift bay is in demand for other work and vehicles and if it is going to be tied up for any period of time, I need to plan that well in advance. Dropping the engine will tie up my lift bay for some time, as I am involved in 100 other things besides working on my 914......actually, working on it is something I do in my spare time......and because of that I don't know how long it will take me to do the work with the flaps. I also don't want to drop the engine twice in a short period of time. It needs a top-end rebuild and I need to plan that out. I'm still not certain of which way I want to go on that. Hopes this helps to explain some of my comments......the problem and issue is timing, not technicals....... GN Wait. You have access to all this. and it... sounds just like a former troll. Just do some work. |
Lo-Fi Version | Time is now: 19th May 2024 - 07:57 PM |
