Major Cooling System issues, Flap system removed by PO |
Gatornapper |
Aug 20 2019, 09:29 AM
Senior Member Group: Members Posts: 1,215 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
Need the Brain Trust help again - big time.
Up to now, nothing I've faced in getting this sweet 14 running and back on the road has been major or disheartening. Lots of new stuff, running pretty good but not perfect, etc. That just changed. Ever since getting the engine running a few months ago, I was concerned that it took a long time to warm up. My first 1 hour + drive was last week - and temps got too high for my comfort - about 1/4" from red line. So I've been drilling down on that issue. For one thing, car sat in a barn (new one) for 12 years - so I wondered about mice nests above the cylinders from the day I bought the car. Yesterday with my scope I found, yes, they are there between the cylinders - at least between 2 & 4. I think I can get them out with a small vacuum through the spark plug holes in the top tins.....we'll see. Due to total ignorance of 914's and VW engines, I know nothing of the air ducting system, but in the learning process, and thanks to anderssj , I find the whole flap/door system and its controls are missing. Gone. So I can only assume that the PO removed them due to problems with overheating. Stupid move for sure. I have to correct that. I understand that move itself could cause overheating. I dread pulling the carbs, intake manifolds, distributor and other stuff to get the top tins off. Plan is to see if I can get the mouse stuff off the cylinders with a small vacuum, make sure all is clean with my scope. If successful, I'll then drive the car and see if it still gets too hot. If I can't get the debris removed with vacuum, I know I have to pull the top tins. But I am told that not having the flap system itself could cause overheating. So I have to get that system installed and working. Yes, I know the many potential causes of overheating like improper timing, plugs, etc. Timing good, plugs good - new. Valves adjusted by dealer about 1,500 miles ago. Got a lot of work ahead - all when I wanted to have the car ready for the big PCA 9/14 914 Vintage Drive. Any help and advice is of course, as always, appreciated. GN |
iankarr |
Aug 24 2019, 10:35 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
I suggest you try to do this with the engine in the car. After about 30 minutes of bending, struggling, and coming to the realization that it’s not really feasible/doable, you’ll resolve yourself to dropping the engine and doing the job, rather than hoping there’s another way. There’s an amazing wealth of knowledge on this site, but it serves no good at all if you don’t utilize it (IMG:style_emoticons/default/smile.gif)
The link in my signature has a video on how to drop the engine. You’ll see that it’s pretty easy, especially if you have the tangerine jack plate (which you’ll see in the video). If you PM, I’m happy to answer any other questions you have. Just get to it! It’ll be done in less time than it took to build this thread. If you have all the parts, the drop/fix/reinstall shouldn’t take more than an afternoon....so your bay can go back to other things. |
Superhawk996 |
Aug 24 2019, 10:38 AM
914 Guru Group: Members Posts: 5,834 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I suggest you try to do this with the engine in the car. After about 30 minutes of bending, struggling, and coming to the realization that it’s not really feasible/doable, you’ll resolve yourself to dropping the engine and doing the job, rather than hoping there’s another way. There’s an amazing wealth of knowledge on this site, but it serves no good at all if you don’t utilize it (IMG:style_emoticons/default/smile.gif) The link in my signature has a video on how to drop the engine. You’ll see that it’s pretty easy, especially if you have the tangerine jack plate (which you’ll see in the video). If you PM, I’m happy to answer any other questions you have. Just get to it! It’ll be done in less time than it took to build this thread. (IMG:style_emoticons/default/av-943.gif) You forgot the 30 minutes to put all the loose stuff back in place that will now likely preclude dropping the engine cleanly! @Gatornapper Not laughing at you -- its just that this subject of whether to drop or not to drop comes up so often its funny on it's own merit. |
Lo-Fi Version | Time is now: 19th May 2024 - 08:10 PM |
