Major Cooling System issues, Flap system removed by PO |
Gatornapper |
Aug 20 2019, 09:29 AM
Senior Member Group: Members Posts: 1,215 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
Need the Brain Trust help again - big time.
Up to now, nothing I've faced in getting this sweet 14 running and back on the road has been major or disheartening. Lots of new stuff, running pretty good but not perfect, etc. That just changed. Ever since getting the engine running a few months ago, I was concerned that it took a long time to warm up. My first 1 hour + drive was last week - and temps got too high for my comfort - about 1/4" from red line. So I've been drilling down on that issue. For one thing, car sat in a barn (new one) for 12 years - so I wondered about mice nests above the cylinders from the day I bought the car. Yesterday with my scope I found, yes, they are there between the cylinders - at least between 2 & 4. I think I can get them out with a small vacuum through the spark plug holes in the top tins.....we'll see. Due to total ignorance of 914's and VW engines, I know nothing of the air ducting system, but in the learning process, and thanks to anderssj , I find the whole flap/door system and its controls are missing. Gone. So I can only assume that the PO removed them due to problems with overheating. Stupid move for sure. I have to correct that. I understand that move itself could cause overheating. I dread pulling the carbs, intake manifolds, distributor and other stuff to get the top tins off. Plan is to see if I can get the mouse stuff off the cylinders with a small vacuum, make sure all is clean with my scope. If successful, I'll then drive the car and see if it still gets too hot. If I can't get the debris removed with vacuum, I know I have to pull the top tins. But I am told that not having the flap system itself could cause overheating. So I have to get that system installed and working. Yes, I know the many potential causes of overheating like improper timing, plugs, etc. Timing good, plugs good - new. Valves adjusted by dealer about 1,500 miles ago. Got a lot of work ahead - all when I wanted to have the car ready for the big PCA 9/14 914 Vintage Drive. Any help and advice is of course, as always, appreciated. GN |
Superhawk996 |
Aug 24 2019, 09:53 AM
914 Guru Group: Members Posts: 5,834 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
On a 914 it is much easier to just drop the engine and then do work.
I constantly see people trying to do work with the engine in the car and often it can be done. BUT, it is so much harder. Only takes about 90 minutes to drop the engine, trans, muffler assembly and then everything is right out in the open. First time will take you longer but honestly once you've done it once, it is so easy after that. In the case of the flaps, you'll need to pull the front fan shroud castings - I honestly don't believe that can be done with the engine in. If it could be done, it will be so much harder that it makes the discussion irrelevant. If you have the luxury of having $$, buy the Tangerine engine lift adapter for your floor jack. I think $129. Makes life so easy. Having said that, the bulk of the the time I owned my 1st 914 I was either in the military as a poor E2/E3 or in college with even less money. I restored my 1st car with nothing more than a K-mart socket set, vice grips, a few screwdrivers, a hammer, and a 1 1/2 ton K-mart floor jack. Dropped the engine many times with nothing more than than what is listed above. I promise dropping the engine isn't that hard and it will save you so much time in the long run. This is true of nearly every mid-engine car whether its a Fiero or a Ferrari. |
ClayPerrine |
Aug 24 2019, 09:55 PM
Life's been good to me so far..... Group: Admin Posts: 15,474 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
In the case of the flaps, you'll need to pull the front fan shroud castings - I honestly don't believe that can be done with the engine in. If it could be done, it will be so much harder that it makes the discussion irrelevant. Yes, it can be done. I have done it. But it is a b1tch putting the fan shroud back on the front of the motor without screwing up the cooling flaps. It is much easier to drop the motor and trans out of the car. If you have a lift, it is even easier. Just unhook all the stuff on top, raise it up, unhook everything but the motor mounts on the bottom. Lower the car down and place jack stands under each end of the crossbar, and one under the rear of the trans. Then unbolt the mounts, and lift the car off the engine and trans. Putting it back is just as easy. If you moved the motor, use a couple of plumb bobs to align the crossbar with the mounts in the frame, then carefully lower the car onto the motor. Watch the CV joints and axles, they have a tendency to hang up on the trans when installing the motor. Good luck. |
Gatornapper |
Aug 25 2019, 07:15 AM
Clay -
Thanks - I'm sold. Think the motorcycle lift table is best tho - puts the engine at a perfect working height, and if need be, allows me to move it - tho I won't plan on doing that due to alignment issues. Next question guys: Why should I drop the engine and NOT do a top-end rebuild, with new C&P's, maybe renewed heads? Thinking of the 2056 upgrade - would love advice on best sources for this.......or should I start a new thread for this? GN QUOTE Yes, it can be done. I have done it. But it is a b1tch putting the fan shroud back on the front of the motor without screwing up the cooling flaps. It is much easier to drop the motor and trans out of the car. If you have a lift, it is even easier. Just unhook all the stuff on top, raise it up, unhook everything but the motor mounts on the bottom. Lower the car down and place jack stands under each end of the crossbar, and one under the rear of the trans. Then unbolt the mounts, and lift the car off the engine and trans. Putting it back is just as easy. If you moved the motor, use a couple of plumb bobs to align the crossbar with the mounts in the frame, then carefully lower the car onto the motor. Watch the CV joints and axles, they have a tendency to hang up on the trans when installing the motor. Good luck. |
Lo-Fi Version | Time is now: 19th May 2024 - 07:58 PM |
