Major Cooling System issues, Flap system removed by PO |
Gatornapper |
Aug 20 2019, 09:29 AM
Senior Member Group: Members Posts: 1,215 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
Need the Brain Trust help again - big time.
Up to now, nothing I've faced in getting this sweet 14 running and back on the road has been major or disheartening. Lots of new stuff, running pretty good but not perfect, etc. That just changed. Ever since getting the engine running a few months ago, I was concerned that it took a long time to warm up. My first 1 hour + drive was last week - and temps got too high for my comfort - about 1/4" from red line. So I've been drilling down on that issue. For one thing, car sat in a barn (new one) for 12 years - so I wondered about mice nests above the cylinders from the day I bought the car. Yesterday with my scope I found, yes, they are there between the cylinders - at least between 2 & 4. I think I can get them out with a small vacuum through the spark plug holes in the top tins.....we'll see. Due to total ignorance of 914's and VW engines, I know nothing of the air ducting system, but in the learning process, and thanks to anderssj , I find the whole flap/door system and its controls are missing. Gone. So I can only assume that the PO removed them due to problems with overheating. Stupid move for sure. I have to correct that. I understand that move itself could cause overheating. I dread pulling the carbs, intake manifolds, distributor and other stuff to get the top tins off. Plan is to see if I can get the mouse stuff off the cylinders with a small vacuum, make sure all is clean with my scope. If successful, I'll then drive the car and see if it still gets too hot. If I can't get the debris removed with vacuum, I know I have to pull the top tins. But I am told that not having the flap system itself could cause overheating. So I have to get that system installed and working. Yes, I know the many potential causes of overheating like improper timing, plugs, etc. Timing good, plugs good - new. Valves adjusted by dealer about 1,500 miles ago. Got a lot of work ahead - all when I wanted to have the car ready for the big PCA 9/14 914 Vintage Drive. Any help and advice is of course, as always, appreciated. GN |
Gatornapper |
Aug 25 2019, 11:35 AM
The PO responded to my query and insists that he did not remove the flap system. That means he owned & drove the car from 2001 to 2006 without the flaps - with no overheating......
Which raises a whole new set of questions.....also learned this was his 3rd 914..... How was car driven for over 5 years with no flaps and no over-heating? I guess we'll never know....... GN |
Superhawk996 |
Aug 25 2019, 11:45 AM
914 Guru Group: Members Posts: 5,834 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
The PO responded to my query and insists that he did not remove the flap system. That means he owned & drove the car from 2001 to 2006 without the flaps - with no overheating...... Which raises a whole new set of questions.....also learned this was his 3rd 914..... How was car driven for over 5 years with no flaps and no over-heating? I guess we'll never know....... GN You may find out when you pull the tin. Wouldn't be surprised to find a mouse house or clogged oil cooler. Also who's to say he was paying attention and didn't overheat it or the previously mentioned girlfriend? Maybe he only drove it a few miles to Dairy Queen for an ice cream only once a year. Who really knows? That is why I make it a personal principle to tear down every engine as if it was a core. Heck I got my original engine (the one without flaps) running before I tore the car apart but seriously had no idea of how much rust and muck was sitting in the sump. No idea that the crank was already 0.010" undersize and scored. It would have run for a while but would have eventually destroyed itself at the most inopportune time. These cars are now 40 - 50 years old and should be assessed as such . . . probably worn out. Had I pulled the engine apart and found it to be pristine, no big deal. Fresh gaskets and it would have gone back together. Ah . . . if only that had been the case. |
Gatornapper |
Aug 25 2019, 11:54 AM
SH -
Totally get it. But, mine does only have 60k miles on it.....pretty sure that's fairly accurate. Debating opening the case if I do the C's & P's.......kinda know I should, but also know it will likely lead to spending money that might not be necessary - like a cam for the carbs..... GN The PO responded to my query and insists that he did not remove the flap system. That means he owned & drove the car from 2001 to 2006 without the flaps - with no overheating...... Which raises a whole new set of questions.....also learned this was his 3rd 914..... How was car driven for over 5 years with no flaps and no over-heating? I guess we'll never know....... GN You may find out when you pull the tin. Wouldn't be surprised to find a mouse house or clogged oil cooler. Also who's to say he was paying attention and didn't overheat it or the previously mentioned girlfriend? Maybe he only drove it a few miles to Dairy Queen for an ice cream only once a year. Who really knows? That is why I make it a personal principle to tear down every engine as if it was a core. Heck I got my original engine (the one without flaps) running before I tore the car apart but seriously had no idea of how much rust and muck was sitting in the sump. No idea that the crank was already 0.010" undersize and scored. It would have run for a while but would have eventually destroyed itself at the most inopportune time. These cars are now 40 - 50 years old and should be assessed as such . . . probably worn out. Had I pulled the engine apart and found it to be pristine, no big deal. Fresh gaskets and it would have gone back together. Ah . . . if only that had been the case. |
Lo-Fi Version | Time is now: 19th May 2024 - 04:12 PM |
