Major Cooling System issues, Flap system removed by PO |
Gatornapper |
Aug 20 2019, 09:29 AM
Senior Member Group: Members Posts: 1,215 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
Need the Brain Trust help again - big time.
Up to now, nothing I've faced in getting this sweet 14 running and back on the road has been major or disheartening. Lots of new stuff, running pretty good but not perfect, etc. That just changed. Ever since getting the engine running a few months ago, I was concerned that it took a long time to warm up. My first 1 hour + drive was last week - and temps got too high for my comfort - about 1/4" from red line. So I've been drilling down on that issue. For one thing, car sat in a barn (new one) for 12 years - so I wondered about mice nests above the cylinders from the day I bought the car. Yesterday with my scope I found, yes, they are there between the cylinders - at least between 2 & 4. I think I can get them out with a small vacuum through the spark plug holes in the top tins.....we'll see. Due to total ignorance of 914's and VW engines, I know nothing of the air ducting system, but in the learning process, and thanks to anderssj , I find the whole flap/door system and its controls are missing. Gone. So I can only assume that the PO removed them due to problems with overheating. Stupid move for sure. I have to correct that. I understand that move itself could cause overheating. I dread pulling the carbs, intake manifolds, distributor and other stuff to get the top tins off. Plan is to see if I can get the mouse stuff off the cylinders with a small vacuum, make sure all is clean with my scope. If successful, I'll then drive the car and see if it still gets too hot. If I can't get the debris removed with vacuum, I know I have to pull the top tins. But I am told that not having the flap system itself could cause overheating. So I have to get that system installed and working. Yes, I know the many potential causes of overheating like improper timing, plugs, etc. Timing good, plugs good - new. Valves adjusted by dealer about 1,500 miles ago. Got a lot of work ahead - all when I wanted to have the car ready for the big PCA 9/14 914 Vintage Drive. Any help and advice is of course, as always, appreciated. GN |
ChrisFoley |
Aug 26 2019, 11:02 AM
I am Tangerine Racing Group: Members Posts: 7,926 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I just pulled the tin off an engine that appeared to have no cooling flaps. The thermostat and crossbar were removed. I tried to pull the shroud off before removing the cylinder tin but it hung up on the passenger side. I was able to look inside and could see that the oil cooler flap was in place, riveted down at the back. That's the warm position, which directs some of the air to the cooler. This engine runs quite hot so I was expecting no flap at all.
Owner has documented 250F in 90+ degree weather climbing hills at 80 mph. Next step is to install one of my remote oil cooler kits so he can run his AC without overheating the engine. |
Gatornapper |
Aug 26 2019, 07:07 PM
Chris -
THANK YOU FOR THIS POST! VERY educational. Anyone else ever seen this mod before? So, you were attempting to access the oil cooler and install the flaps and thermostat without removing the engine? And you are a professional 914 mechanic, right? But you could not get the front shroud off.....did you get the right front tin off? Sorry for all the questions, just trying to understand where I've never been before.....and the Haynes manual is as clear as mud....... Is it your opinion that the riveted flap was not far enough in the "hot" position, and that's why the engine is overheating? What is a proper engine temp on a 90 degree day climbing hills at 80mph?????? 230? 235? I'm sure it is above 220........ I assume your remote cooler, as all I've seen so far, is located up front below the bumper.....correct? I think that's enough questions for one post...... GN I just pulled the tin off an engine that appeared to have no cooling flaps. The thermostat and crossbar were removed. I tried to pull the shroud off before removing the cylinder tin but it hung up on the passenger side. I was able to look inside and could see that the oil cooler flap was in place, riveted down at the back. That's the warm position, which directs some of the air to the cooler. This engine runs quite hot so I was expecting no flap at all. Owner has documented 250F in 90+ degree weather climbing hills at 80 mph. Next step is to install one of my remote oil cooler kits so he can run his AC without overheating the engine. |
Lo-Fi Version | Time is now: 19th May 2024 - 03:51 PM |
