Questions About a New Steering Wheel / Hub Combo, Match-up Mystery |
jtprettyman |
Aug 20 2019, 12:51 PM
Rust Bucket Owner Group: Members Posts: 109 Joined: 5-May 15 From: Murfreesboro Tennessee Member No.: 18,707 Region Association: South East States |
I recently picked up a new steering wheel and adapter for my 74 project, and now wondering a bit about what I ended up with. Wheel was listed as a "President" brand wheel in the Momo pattern, but doesn't fit the adapter - the bolt pattern is correct, but the hub bore size doesn't fit the adapter (49.5mm vs 52.75mm). First glance looks to be a Momo A-8002 adapter, but not sure about this wheel. Anyone have some insight on these?
sixnotfour |
Aug 20 2019, 01:09 PM
914 Wizard Group: Members Posts: 10,422 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
do you have a horn button ??
SirAndy |
Aug 20 2019, 01:10 PM
Resident German Group: Admin Posts: 41,623 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Never seen that brand but you can tell from the shape of the mounting holes that it won't fit the momo hub, the holes aren't tapered to fit the screw heads.
(IMG:style_emoticons/default/idea.gif) |
jtprettyman |
Aug 20 2019, 01:16 PM
do you have a horn button ?? No, I do not have a horn button as of yet. Never seen that brand but you can tell from the shape of the mounting holes that it won't fit the momo hub, the holes aren't tapered to fit the screw heads. (IMG:style_emoticons/default/idea.gif) Yes, no countersink on the wheel for the provided screws. The adapter and screws were an afterthought, seller asked me if I need one after the purchase of the wheel. Nothing against the seller, don't think he ever had them together. Just wondering exactly what I ended up with here as the wheel is a bit of a mystery to me. |
sixnotfour |
Aug 20 2019, 01:22 PM
the new style does not use the centering boss...
I would get a momo horn button and care fully dremel out the bore of the wheel to fit hub.. use button head or std allen bolts Attached image(s) |
jtprettyman |
Aug 22 2019, 10:54 AM
Is anyone familiar with the 'President' brand wheel? Haven't been able to find much of anything on the internet about them. Planning on opening up the ID to fit the hub, but can just as easily grab another wheel if this one had any particular value to another application.
sixnotfour |
Aug 22 2019, 02:06 PM
????????? momo was patpending everything maybe they got stopped ???
Attached image(s) |
iamchappy |
Aug 22 2019, 02:54 PM
It all happens so fast! Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
You might want to check out these, they may have a hub for you that works, i got one from them that works with my Raid wheel.
http://www.tekniqauto.com/US/steeringquickrelease.htm Looks like they rebranded http://snapoff.com/racing/ |
Lo-Fi Version | Time is now: 6th May 2024 - 02:54 PM |
