Horn pad fitment, |
Horn pad fitment, |
dt4 |
Aug 21 2019, 05:43 AM
Senior Member Group: Members Posts: 502 Joined: 26-May 19 From: England Member No.: 23,161 Region Association: England |
I am presuming that when the pad twists and locks into place it should be pretty secure?
I have tried it numerous times and have repositioned the plate on the back of the pad in all its possible orientations but the fit is really loose Is there a knack or some way of adjusting the fit? |
Minerva's 914 |
Aug 21 2019, 06:24 AM
Member Group: Members Posts: 378 Joined: 24-December 15 From: Chapel Hill, NC Member No.: 19,489 Region Association: South East States |
I am presuming that when the pad twists and locks into place it should be pretty secure? I have tried it numerous times and have repositioned the plate on the back of the pad in all its possible orientations but the fit is really loose Is there a knack or some way of adjusting the fit? Check the horn rubber, may be worn or missing. 914Rubber makes a replacement https://900designs-container.zoeysite.com/s...orn-rubber-cuff |
Mike Fitton |
Aug 21 2019, 06:47 AM
Senior Member Group: Members Posts: 609 Joined: 13-May 11 From: Chicago Area Member No.: 13,069 Region Association: Upper MidWest |
Tension spring is probably broken, it is the piece with the 3 loops.
dt4 |
Aug 21 2019, 07:00 AM
dt4 |
Aug 21 2019, 07:14 AM
dr914@autoatlanta.com |
Aug 21 2019, 07:48 AM
914 Guru Group: Members Posts: 7,838 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
tighten the three screws and make sure a horn boot is installed, also look at the three prongs on the horn spring and make sure that the strap spring ends are not broken
I am presuming that when the pad twists and locks into place it should be pretty secure? I have tried it numerous times and have repositioned the plate on the back of the pad in all its possible orientations but the fit is really loose Is there a knack or some way of adjusting the fit? |
Aug 21 2019, 07:52 AM
dt4 |
Aug 21 2019, 02:12 PM
tighten the three screws and make sure a horn boot is installed, also look at the three prongs on the horn spring and make sure that the strap spring ends are not broken I am presuming that when the pad twists and locks into place it should be pretty secure? I have tried it numerous times and have repositioned the plate on the back of the pad in all its possible orientations but the fit is really loose Is there a knack or some way of adjusting the fit? which part is a horn boot? can you spot it on the photo? |
Aug 21 2019, 02:26 PM
the horn boot is missing looks like a squashed black megaphone
FlacaProductions |
Aug 21 2019, 02:55 PM
Senior Member Group: Members Posts: 1,570 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
dt4 |
Aug 21 2019, 03:12 PM
(IMG:style_emoticons/default/beerchug.gif) I will look through the boxes of parts and see if it is there, if not I am sure I will be putting in an order for things that need replacing / are missing so I'll put a list together as the exchange rate plus shipping is going to be a killer so I dont want to be placing frequent small orders |
sithot |
Aug 24 2019, 08:17 PM
Member Group: Members Posts: 446 Joined: 25-October 06 From: Virginia Member No.: 7,090 Region Association: None |
Where does one find the "bakelite" (?) insulators that stand-off the tension spring from the horn plate?
I used some fiber washers on two of mine that were "too close to call" for creating a problem. Thanks! Tom |
raynekat |
Aug 25 2019, 02:13 AM
Advanced Member Group: Members Posts: 2,158 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Where does one find the "bakelite" (?) insulators that stand-off the tension spring from the horn plate? I used some fiber washers on two of mine that were "too close to call" for creating a problem. Thanks! Tom Reproduction kit is here: https://sierramadrecollection.com/Horn-Butt...-76-p21568.html |
sithot |
Aug 25 2019, 04:45 AM
Where does one find the "bakelite" (?) insulators that stand-off the tension spring from the horn plate? I used some fiber washers on two of mine that were "too close to call" for creating a problem. Thanks! Tom Reproduction kit is here: https://sierramadrecollection.com/Horn-Butt...-76-p21568.html Thank you. (IMG:style_emoticons/default/beerchug.gif) |
mmichalik |
Aug 25 2019, 11:31 AM
MikeM Group: Members Posts: 696 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California |
I had the exact same problem, sloppy horn button on the '74
Put that $14.00 rubber boot in there and it feels brand new. Hope that works for you and thanks to everyone who put out the suggestions. |
dt4 |
Aug 25 2019, 12:44 PM
Lo-Fi Version | Time is now: 7th May 2024 - 06:15 PM |
