Horn pad fitment, |
Horn pad fitment, |
dt4 |
Aug 21 2019, 05:43 AM
Senior Member Group: Members Posts: 503 Joined: 26-May 19 From: England Member No.: 23,161 Region Association: England |
I am presuming that when the pad twists and locks into place it should be pretty secure?
I have tried it numerous times and have repositioned the plate on the back of the pad in all its possible orientations but the fit is really loose Is there a knack or some way of adjusting the fit? |
dr914@autoatlanta.com |
Aug 21 2019, 07:48 AM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
tighten the three screws and make sure a horn boot is installed, also look at the three prongs on the horn spring and make sure that the strap spring ends are not broken
I am presuming that when the pad twists and locks into place it should be pretty secure? I have tried it numerous times and have repositioned the plate on the back of the pad in all its possible orientations but the fit is really loose Is there a knack or some way of adjusting the fit? |
dt4 |
Aug 21 2019, 02:12 PM
tighten the three screws and make sure a horn boot is installed, also look at the three prongs on the horn spring and make sure that the strap spring ends are not broken I am presuming that when the pad twists and locks into place it should be pretty secure? I have tried it numerous times and have repositioned the plate on the back of the pad in all its possible orientations but the fit is really loose Is there a knack or some way of adjusting the fit? which part is a horn boot? can you spot it on the photo? |
Aug 21 2019, 02:26 PM
the horn boot is missing looks like a squashed black megaphone
Lo-Fi Version | Time is now: 19th May 2024 - 10:22 AM |
