Horn pad fitment, |
Horn pad fitment, |
dt4 |
Aug 21 2019, 05:43 AM
Senior Member Group: Members Posts: 503 Joined: 26-May 19 From: England Member No.: 23,161 Region Association: England |
I am presuming that when the pad twists and locks into place it should be pretty secure?
I have tried it numerous times and have repositioned the plate on the back of the pad in all its possible orientations but the fit is really loose Is there a knack or some way of adjusting the fit? |
FlacaProductions |
Aug 21 2019, 02:55 PM
Senior Member Group: Members Posts: 1,589 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
dt4 |
Aug 21 2019, 03:12 PM
(IMG:style_emoticons/default/beerchug.gif) I will look through the boxes of parts and see if it is there, if not I am sure I will be putting in an order for things that need replacing / are missing so I'll put a list together as the exchange rate plus shipping is going to be a killer so I dont want to be placing frequent small orders |
sithot |
Aug 24 2019, 08:17 PM
Member Group: Members Posts: 446 Joined: 25-October 06 From: Virginia Member No.: 7,090 Region Association: None |
Where does one find the "bakelite" (?) insulators that stand-off the tension spring from the horn plate?
I used some fiber washers on two of mine that were "too close to call" for creating a problem. Thanks! Tom |
raynekat |
Aug 25 2019, 02:13 AM
Advanced Member Group: Members Posts: 2,158 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Where does one find the "bakelite" (?) insulators that stand-off the tension spring from the horn plate? I used some fiber washers on two of mine that were "too close to call" for creating a problem. Thanks! Tom Reproduction kit is here: https://sierramadrecollection.com/Horn-Butt...-76-p21568.html |
sithot |
Aug 25 2019, 04:45 AM
Where does one find the "bakelite" (?) insulators that stand-off the tension spring from the horn plate? I used some fiber washers on two of mine that were "too close to call" for creating a problem. Thanks! Tom Reproduction kit is here: https://sierramadrecollection.com/Horn-Butt...-76-p21568.html Thank you. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 09:17 AM |
