Seat Belt Relay Wiring, Help ID wires |
Ed_Turbo |
Aug 25 2019, 03:22 PM
Member Group: Members Posts: 440 Joined: 5-June 17 From: Hacienda Heights, Ca. Member No.: 21,151 Region Association: Southern California |
Hello! I am trying to ID these wires:
I am not good at wiring diagrams and I found no luck researching this topic (IMG:style_emoticons/default/confused24.gif) Enlighten me with your Jedi wiring knowledge @JeffBowlsby @Dave_Darling and anyone else who are pros at wiring 914’s. -Ed Attached thumbnail(s) |
jim_hoyland |
Aug 25 2019, 06:00 PM
Get that VIN ? Group: Members Posts: 9,265 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I would like to know how the relay works; after learning how the dual relay on the L-Jet functions, it made it easier to diagnose problems and is just interesting |
Chi-town |
Aug 25 2019, 06:46 PM
The ones with the wire nuts appear to be the buckle and seat sensor wires.
The relay plugs into the board there so no mystery there. Take the two large yellow wires and connect them together to bypass the silly logic. |
FlacaProductions |
Aug 25 2019, 06:49 PM
Senior Member Group: Members Posts: 1,565 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Connect the black wire to the black/red stripe and that should give you power to the light in the backpad if you don't have it already.
FlacaProductions |
Aug 25 2019, 06:50 PM
Here's a shot that I've saved from here that shows how it should be....
jcd914 |
Aug 25 2019, 06:55 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
I don't have details on how it is supposed to work and the diagrams I have don't have the relay and wiring on them.
The general consensus is that it more often doesn't work correctly. It is supposed to turn on the seatbelt warning light on the dash AND lock out the starter if the seatbelts are not fastened. There is a pressure switch in the passenger seat and there are switches in each seatbelt receiver to determine if the belts are buckled. When you try to start the engine if your seatbelt is not fastened the starter won't crank and if you have a passenger their seatbelt has to be fastened too. The two important wires are the large yellow and yellow with red stripe. These are the power from the ignition switch to the starter and should be pulled from the relay socket and securly connected together. That way when one of the seatbelt receiver switches, seat pressure switch or relay fail you will still be able to start your car. Jim |
FlacaProductions |
Aug 25 2019, 06:57 PM
@jcd914 - I think you mean Yellow and Yellow/red stripe need to be connected as pictured in my post. Those are the important ones and it looks like he already has that taken care of.
JeffBowlsby |
Aug 25 2019, 07:01 PM
914 Wiring Harnesses Group: Members Posts: 8,485 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
It’s not a relay it’s a logic box. Diagrammed on the FWSM wiring schematic.
jcd914 |
Aug 25 2019, 07:03 PM
@jcd914 - I think you mean Yellow and Yellow/red stripe need to be connected as pictured in my post. Those are the important ones and it looks like he already has that taken care of. Thanks, I corrected my post. Jim |
jcd914 |
Aug 25 2019, 07:10 PM
It’s not a relay it’s a logic box. Diagrammed on the FWSM wiring schematic. In that logic box, there is a relay that controls the starter circuit. So good enough for me. I didn't find it on the diagrams I have which came from Pelican website when they had them there. I only looked at the 72 & 73 diagrams, they just have the starter circuit going from ignition switch to the relay panel in the engine compartment. With diagram is it on? Thanks Jim |
ClayPerrine |
Aug 25 2019, 07:57 PM
Life's been good to me so far..... Group: Admin Posts: 15,416 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
It’s not a relay it’s a logic box. Diagrammed on the FWSM wiring schematic. In that logic box, there is a relay that controls the starter circuit. So good enough for me. I didn't find it on the diagrams I have which came from Pelican website when they had them there. I only looked at the 72 & 73 diagrams, they just have the starter circuit going from ignition switch to the relay panel in the engine compartment. With diagram is it on? Thanks Jim They started installing that crap in 74. There is a wire in there that comes from the ignition fuse on the fuse panel. Make sure you drop the fuse panel and cut that wire out of the circuit for the ignition. If it gets loose from the plug, it will bounce against ground and cause the car to die randomly. That drove Betty crazy for a while when we were dating. I found it and disconnected it. I have since removed all of that seatbelt interlock crap from her car. Even the bracket on the floor pan was removed. (IMG:style_emoticons/default/ar15.gif) |
jim_hoyland |
Aug 25 2019, 08:28 PM
It’s not a relay it’s a logic box. Diagrammed on the FWSM wiring schematic. Ok; any idea of the logic applied to the circuit . (IMG:style_emoticons/default/smile.gif) |
Rand |
Aug 25 2019, 08:30 PM
Cut it all. Join the big yellow because it's the one that matters. Join the little browns... may not matter but they are grounds and it's a good idea. Run away laughing happily.
JeffBowlsby |
Aug 26 2019, 05:58 AM
Just bypass it by mating the two big yellow wires. Cutting out wires is dangerous and unnecessary - who knows what won't work if you give it a wire-ectomy.
porschetub |
Aug 26 2019, 02:06 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Mines bypassed but I would still like to get rid of the rest,I have removed everthing from my car that is not needed,would be nice to get rid of this lot.
914werke |
Aug 26 2019, 02:34 PM
"I got blisters on me fingers" Group: Members Posts: 10,027 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Cut it all. Run away laughing happily. (IMG:style_emoticons/default/biggrin.gif) @Rand I think your fast approaching Crusty status. ...perhaps a screen name change is in your future: Lt. Crusty? (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 29th April 2024 - 07:33 AM |
