Seat Belt Relay Wiring, Help ID wires |
Ed_Turbo |
Aug 25 2019, 03:22 PM
Member Group: Members Posts: 440 Joined: 5-June 17 From: Hacienda Heights, Ca. Member No.: 21,151 Region Association: Southern California |
Hello! I am trying to ID these wires:
I am not good at wiring diagrams and I found no luck researching this topic (IMG:style_emoticons/default/confused24.gif) Enlighten me with your Jedi wiring knowledge @JeffBowlsby @Dave_Darling and anyone else who are pros at wiring 914’s. -Ed Attached thumbnail(s) |
jcd914 |
Aug 25 2019, 06:55 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
I don't have details on how it is supposed to work and the diagrams I have don't have the relay and wiring on them.
The general consensus is that it more often doesn't work correctly. It is supposed to turn on the seatbelt warning light on the dash AND lock out the starter if the seatbelts are not fastened. There is a pressure switch in the passenger seat and there are switches in each seatbelt receiver to determine if the belts are buckled. When you try to start the engine if your seatbelt is not fastened the starter won't crank and if you have a passenger their seatbelt has to be fastened too. The two important wires are the large yellow and yellow with red stripe. These are the power from the ignition switch to the starter and should be pulled from the relay socket and securly connected together. That way when one of the seatbelt receiver switches, seat pressure switch or relay fail you will still be able to start your car. Jim |
Lo-Fi Version | Time is now: 15th May 2024 - 11:18 PM |
