Seat Belt Relay Wiring, Help ID wires |
Ed_Turbo |
Aug 25 2019, 03:22 PM
Member Group: Members Posts: 440 Joined: 5-June 17 From: Hacienda Heights, Ca. Member No.: 21,151 Region Association: Southern California |
Hello! I am trying to ID these wires:
I am not good at wiring diagrams and I found no luck researching this topic (IMG:style_emoticons/default/confused24.gif) Enlighten me with your Jedi wiring knowledge @JeffBowlsby @Dave_Darling and anyone else who are pros at wiring 914’s. -Ed Attached thumbnail(s) |
JeffBowlsby |
Aug 25 2019, 07:01 PM
914 Wiring Harnesses Group: Members Posts: 8,507 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
It’s not a relay it’s a logic box. Diagrammed on the FWSM wiring schematic.
jcd914 |
Aug 25 2019, 07:10 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
It’s not a relay it’s a logic box. Diagrammed on the FWSM wiring schematic. In that logic box, there is a relay that controls the starter circuit. So good enough for me. I didn't find it on the diagrams I have which came from Pelican website when they had them there. I only looked at the 72 & 73 diagrams, they just have the starter circuit going from ignition switch to the relay panel in the engine compartment. With diagram is it on? Thanks Jim |
ClayPerrine |
Aug 25 2019, 07:57 PM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
It’s not a relay it’s a logic box. Diagrammed on the FWSM wiring schematic. In that logic box, there is a relay that controls the starter circuit. So good enough for me. I didn't find it on the diagrams I have which came from Pelican website when they had them there. I only looked at the 72 & 73 diagrams, they just have the starter circuit going from ignition switch to the relay panel in the engine compartment. With diagram is it on? Thanks Jim They started installing that crap in 74. There is a wire in there that comes from the ignition fuse on the fuse panel. Make sure you drop the fuse panel and cut that wire out of the circuit for the ignition. If it gets loose from the plug, it will bounce against ground and cause the car to die randomly. That drove Betty crazy for a while when we were dating. I found it and disconnected it. I have since removed all of that seatbelt interlock crap from her car. Even the bracket on the floor pan was removed. (IMG:style_emoticons/default/ar15.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 04:14 PM |
