FS 1973 Signal Orange 914/4 1.7L, Revised ad and lower price |
tmc914 |
Aug 25 2019, 06:07 PM
Member Group: Members Posts: 116 Joined: 24-September 17 From: Lowell, MA Member No.: 21,452 Region Association: North East States |
1973 Signal Orange 1.7L with odometer reading of 81k miles. True mileage is unknown. This is a fun car to drive. It looks nice but could use some work. This has been kept in a garage since I bought it. Best way is to list with pro’s and cons. My intent is to show you the good and bad, then you can decide if this is the car for you. I’m selling this car because I don’t drive it that much and bought a new car.
For sale at reduced price of $6,000 or best reasonable offer. My plan is to offer it here first and then off to ebay in the near future. Here is a link to more pictures: https://flic.kr/s/aHsmGupkts Pro’s: Exterior paint in good condition New front brakes Back brakes in good condition Fuel pump relocated to front compartment to prevent vapor lock Fuel lines replaced Replaced 3 out of 4 wheel bearings (4th in good condition) New tie rod ends Tune up done 3k miles ago that includes new oil and filter, adjust valves, set timing and 4 wheel alignment Has stainless steel heat exchangers Has side shift transmission “Hell hole” has been repaired Longs have also been repaired Replaced many rubber parts like dash to windshield seal, trunk seals ect. Replaced rear taillight lens Original fuel injection Registered and passed safety inspection Now the Con’s: The big rust areas are trunk, bottom of both doors, also door sills Rear defroster does not work Fresh air fan does not work Heat does not work (missing parts) Driver’s side window does not line up properly Engine drips small amount of oil when parked Front dashboard has cracks and has cap on it Gas fuel sender works on half tank or less of fuel Drivers side outside door handle does not always work |
Lo-Fi Version | Time is now: 18th May 2024 - 05:37 AM |
