Breaking in New Engine, Leaks...crankcase pressure? |
BeatNavy |
Sep 6 2019, 03:06 PM
The last week or so I've been breaking in a new engine I built last winter and finally manage to install a couple of weeks ago. I'm pretty happy with how it pulls, and after a LOT of fiddling with the MPS and timing I think I've got it where it will start right up, idle cold (barely), idle nicely when warm, and run with nice cool head temps. I do seem to have a slight bit of ping/detonation under load around 2800 to 3000 RPM, so I guess I need to play with timing a bit more.
I am much less happy with the oil leaks. I know building a leak-free Type IV is a challenge, and given this is my first effort, I didn't expect perfection. But right now it's leaking pretty badly in a couple of places: out of the transmission weep hole (probably RMS, I guess), somewhere around oil filter console and/or pressure relief valve, and, surprisingly, what seems to be sort of spraying out and around oil filler neck. Here I need help from the World; I see a combination of three possible causes for this many leaks (when I otherwise took my time and tried to follow guidelines, using Jake's recommended sealants): 1. My own inexperience 2. Too much crankcase pressure from rings not seating yet 3. Too much crankcase pressure from no head venting. Here are some details on build: 2056 with 9950 Cam using D-Jet Brand new AA Heads built by HAM, and Len sealed up the vents 96mm KB Pistons with Hastings Rings 8.6 CR A couple of notes: I didn't gap the rings per Jake's philosophy that crankcase pressure is what causes oil leaks, and the rings come properly gapped. Also, Len (and Jake) don't like head venting for oil flow (so my heads had vent plugged). If I understand him correctly, Len told me the stock PCV vale should provide enough crankcase pressure relief on a street car. RMS is the Sabo brand (the "good" one). Any thoughts on 1, 2 or 3 above? I'm willing to pull the engine and reseal, but I wanted to see if 2 or 3 are possibilities that I need to address. Is the stock PCV valve (which I am sure is not clogged) enough pressure relief? Thanks for any help. |
Superhawk996 |
Sep 10 2019, 06:18 PM
914 Guru Group: Members Posts: 5,824 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Try this trick for item #3. Anneal the copper exhaust gaskets for a better seal.
Heat to dull red with torch, drop in water. Now you have a dead soft copper exhaust seal that will deform nicely to the heat exhanger pipe. Still need to make sure pipe mating surface is reasonably squared and snugged in all the way but soft copper seal will help a bit. Don't go crazy over tightening the exhaust studs trying to pull a poorly fitting or cocked heat exchanger flange home. That doesn't end well. Ask me how I know. (IMG:style_emoticons/default/headbang.gif) |
BeatNavy |
Sep 10 2019, 07:05 PM
Try this trick for item #3. Anneal the copper exhaust gaskets for a better seal. Heat to dull red with torch, drop in water. Now you have a dead soft copper exhaust seal that will deform nicely to the heat exhanger pipe. Still need to make sure pipe mating surface is reasonably squared and snugged in all the way but soft copper seal will help a bit. Don't go crazy over tightening the exhaust studs trying to pull a poorly fitting or cocked heat exchanger flange home. That doesn't end well. Ask me how I know. (IMG:style_emoticons/default/headbang.gif) Good stuff, yes, thanks. In the past I have annealed the rings with good results, but I did not do that this time. Don't ask me why (ok, I was "in a hurry"...to do it half-assed). I did the shop vac blower test which has also worked for me in the past. Sure enough, HE on 1/2 side was leaking big time. Waiting for new exhaust nuts to arrive. On item #1, oil temp gauge or temp sensor could be offset by 10F or more degrees. IR temp check the case sump immediately upon shut down as a 2nd check or if you have access to a Fluke thermocouple reader, I'd drop thermoucouple down the dipstick tube into the oil to get a 2nd data point to check the gauge accuracy. Good idea. Buying an IR thermometer now. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:55 PM |
