Rocker Replacement - Screws for Rivets, Sheet metal screw size? |
FlacaProductions |
Sep 8 2019, 11:09 AM
Senior Member Group: Members Posts: 1,595 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Done a lot of reading on old threads here and have found that sizes for the bolts on the bottom of the rocker covers are 6MM X 12 (or 16 mm long) and the two screws in the fender well are #8X3/4 - but I can't find reference for a sheet metal screw size if you switch from rivets across the top...
Thanks! |
mlindner |
Sep 9 2019, 07:37 AM
Senior Member Group: Members Posts: 1,523 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
I did two 914's at work and had some problems. One, holes sizes all over the place.....two fiberglass rocker will crack out using rivets. One of the cars and mine at home I used the black screws that have a collar around them. Looks a little bigger but works really well. Not sure of the size, will have to buy a few and test. Best, Mark
Lo-Fi Version | Time is now: 28th May 2024 - 08:14 AM |
