Rocker Replacement - Screws for Rivets, Sheet metal screw size? |
FlacaProductions |
Sep 8 2019, 11:09 AM
Senior Member Group: Members Posts: 1,595 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Done a lot of reading on old threads here and have found that sizes for the bolts on the bottom of the rocker covers are 6MM X 12 (or 16 mm long) and the two screws in the fender well are #8X3/4 - but I can't find reference for a sheet metal screw size if you switch from rivets across the top...
Thanks! |
Spoke |
Sep 9 2019, 07:44 AM
Jerry Group: Members Posts: 6,986 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I got several sizes of metal screws and used the ones that fit. #6 or #8, 3/8 inch. As long as the head doesn't interfere with the door you'll be ok. You can file down the head if too tall. I don't like the rivets as it makes it difficult to remove the rocker panels for quick clean outs. The 914 was a low budget car thus pop rivet the rockers and weld on the muffler heat shield.
Lo-Fi Version | Time is now: 28th May 2024 - 03:48 AM |
