Rocker Replacement - Screws for Rivets, Sheet metal screw size? |
FlacaProductions |
Sep 8 2019, 11:09 AM
Senior Member Group: Members Posts: 1,595 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Done a lot of reading on old threads here and have found that sizes for the bolts on the bottom of the rocker covers are 6MM X 12 (or 16 mm long) and the two screws in the fender well are #8X3/4 - but I can't find reference for a sheet metal screw size if you switch from rivets across the top...
Thanks! |
dr914@autoatlanta.com |
Sep 9 2019, 08:37 AM
914 Guru Group: Members Posts: 7,873 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
too many have wallowed out the rivet holes in the top unfortunately necessitating larger rivets or screws, use the factory plastic rivets like previously stated if you can
Lo-Fi Version | Time is now: 28th May 2024 - 07:01 AM |
