Rocker Replacement - Screws for Rivets, Sheet metal screw size? |
FlacaProductions |
Sep 8 2019, 11:09 AM
Senior Member Group: Members Posts: 1,589 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Done a lot of reading on old threads here and have found that sizes for the bolts on the bottom of the rocker covers are 6MM X 12 (or 16 mm long) and the two screws in the fender well are #8X3/4 - but I can't find reference for a sheet metal screw size if you switch from rivets across the top...
Thanks! |
Mikey914 |
Sep 9 2019, 02:58 PM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Got the pop rivets in black if you need them
https://900designs-container.zoeysite.com/r...black-aluminum- The screws are the cheese head ones like the engine tin use. I use the stainless allen screws as they are easier to remove and you don't see them have those also if you need them https://900designs-container.zoeysite.com/e...nd-washer-set-1 |
Lo-Fi Version | Time is now: 19th May 2024 - 02:52 AM |
