Rocker Replacement - Screws for Rivets, Sheet metal screw size? |
FlacaProductions |
Sep 8 2019, 11:09 AM
Senior Member Group: Members Posts: 1,589 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Done a lot of reading on old threads here and have found that sizes for the bolts on the bottom of the rocker covers are 6MM X 12 (or 16 mm long) and the two screws in the fender well are #8X3/4 - but I can't find reference for a sheet metal screw size if you switch from rivets across the top...
Thanks! |
mepstein |
Sep 13 2019, 09:09 PM
914-6 GT in waiting Group: Members Posts: 19,274 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Porsche used plastic rivets so you could remove them with a razor blade and not have to drill them out.
TonyA |
Nov 20 2019, 08:37 AM
Nachmal Group: Members Posts: 470 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States |
Porsche used plastic rivets so you could remove them with a razor blade and not have to drill them out. What gun do/did you use for the plastic rivets? I got some plastic rivets a few years ago and the stem seemed to be to short for any of my rivet guns and also to thin to grab. |
Lo-Fi Version | Time is now: 19th May 2024 - 02:52 AM |
