Rocker Replacement - Screws for Rivets, Sheet metal screw size? |
FlacaProductions |
Sep 8 2019, 11:09 AM
Senior Member Group: Members Posts: 1,589 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Done a lot of reading on old threads here and have found that sizes for the bolts on the bottom of the rocker covers are 6MM X 12 (or 16 mm long) and the two screws in the fender well are #8X3/4 - but I can't find reference for a sheet metal screw size if you switch from rivets across the top...
Thanks! |
mepstein |
Sep 13 2019, 09:09 PM
914-6 GT in waiting Group: Members Posts: 19,274 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Porsche used plastic rivets so you could remove them with a razor blade and not have to drill them out.
TonyA |
Nov 20 2019, 08:37 AM
Nachmal Group: Members Posts: 470 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States |
Porsche used plastic rivets so you could remove them with a razor blade and not have to drill them out. What gun do/did you use for the plastic rivets? I got some plastic rivets a few years ago and the stem seemed to be to short for any of my rivet guns and also to thin to grab. |
914forme |
Nov 20 2019, 02:56 PM
Porsche used plastic rivets so you could remove them with a razor blade and not have to drill them out. What gun do/did you use for the plastic rivets? I got some plastic rivets a few years ago and the stem seemed to be to short for any of my rivet guns and also to thin to grab. Most of them are meant to be driven in to expand the fingers and not pulled out. Short pin is a sign that it goes into the rivet and expands the fingers. |
Lo-Fi Version | Time is now: 19th May 2024 - 04:30 AM |
