| ballsyfacts914 |
Sep 14 2019, 01:30 PM
Member ![]() ![]() Group: Members Posts: 82 Joined: 28-August 19 From: East Bay Region-SF Bay Area Member No.: 23,413 Region Association: Northern California |
The shift rod has a pin right after the firewall that connects the rod to the transmission. Both of the bushings were completely gone, as in not even there. Not really sure how I drove it home. Everything I can find shows how to remove the pin but the bushings are part of the process...I don't have bushings so everything on removal doesn't work.
I have tried using a vice, I have tried a punch but nothing friggin works... (IMG:style_emoticons/default/blink.gif) I have managed to damage ever so slightly one end of the pin but don't think it is a big deal, no mushrooming. How do I get this damn pin out? Thanks |
| JOEPROPER |
Sep 14 2019, 01:34 PM
The answer is "no" unless you ask... ![]() ![]() ![]() Group: Members Posts: 1,208 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States
I did mine today. I pressed it out with a hydraulic press, but you can use a bench vise if you have a decent one. 914Rubber has all the bushings or you can buy as a kit with a new boot and everything. Mine went pretty smooth, so while I was in there, I cleaned and painted the rod.
| rhodyguy |
Sep 14 2019, 01:59 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Did you try pushing the pin into a deep socket with the vise? Big enough to receive the pin and rest on the bushings. Use an about the same diameter, just smaller the pin, bolt. Hold the bolt with a pair of vise grips. A little penetrant would help.
| ballsyfacts914 |
Sep 14 2019, 04:18 PM
I went to a machine shop that had a 20 ton press and had them drive it out for a 12 pack of beer! (IMG:style_emoticons/default/beer.gif)
| mtndawg |
Sep 15 2019, 09:12 AM
Member ![]() ![]() Group: Members Posts: 414 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None
| IronHillRestorations |
Sep 15 2019, 03:22 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,906 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
I also use a vise with a couple sockets, one 1/4" drive just smaller than the diameter of the pin and a deep well socket on the other side; and heat if required. I've taken dozens of those apart and I have had only had one that I couldn't get the pin out.
Lo-Fi Version | Time is now: 16th January 2026 - 03:20 AM |
