Creamsicle questions |
flywheel |
Sep 16 2019, 01:53 PM
Newbie Group: Members Posts: 3 Joined: 8-September 19 From: Las Vegas, NV Member No.: 23,445 Region Association: Southwest Region |
So I just picked up a Creamsicle that was in the process of being restored. Got it from a deceased estate.
There doesn't seem to be any engine number on the top of the block. How important is this? I've found an engine block that fits into the right numbering sequence. Should I buy that or not worry about it? Also does anyone have some good sources for upholstery, door regulators, door & window seals, hoses, etc |
914werke |
Sep 16 2019, 02:28 PM
"I got blisters on me fingers" Group: Members Posts: 10,041 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
What are your goals for the car?
flywheel |
Sep 16 2019, 03:56 PM
I plan on keeping her as original as possible.
Virtually everything is here. The body has been restored and the car repainted in the ivory. It's just a matter of putting her back together with lots of new parts & adding the Phoenix Red color scheme. I'm not going to cut corners. The car has done 32,000 miles but motor cannot be the original as the serial number is missing. It turns over but I'm going to strip it & rebuild it. Do you have any good resources for parts? Upholstery? Window regulators? Rubber door seals, window seals, etc Thanks in advance What are your goals for the car? |
FlacaProductions |
Sep 16 2019, 04:27 PM
Senior Member Group: Members Posts: 1,570 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
rubber and more from (everybody say it with me...) www.914rubber.com
make sure to add the VIN to the database here as well as the LE Registry: http://bowlsby.net/914/CanAm/914CanAmRegistry.htm |
914Sixer |
Sep 17 2019, 01:23 PM
914 Guru Group: Members Posts: 8,876 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
IF it has tan interior there are no correct materials available for the interior. IF black your home free.
Engine MAY BE a replacement engine. Any documentation would be extremely helpful. 914Rubber has all you seals covered. Put WTB in classified section for window regulators. |
Johny Blackstain |
Sep 23 2019, 05:57 PM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
IF it has tan interior there are no correct materials available for the interior. IF black your home free. Engine MAY BE a replacement engine. Any documentation would be extremely helpful. 914Rubber has all you seals covered. Put WTB in classified section for window regulators. Mark, you are 100% correct except it's not tan, it's officially called "cinnamon" & nobody has matched it. Auto Atlanta has carpeting that's close, but not the right shade (darker). Attached thumbnail(s) |
Lo-Fi Version | Time is now: 5th May 2024 - 01:53 PM |
