| surfdogskier |
Sep 23 2019, 07:52 AM
Member ![]() ![]() Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None |
Hey guys,
When I got my car, it was a mess. Wires everywhere. Something is killing my battery after a couple of days. I have numerous wires going to my positive terminal. I have no idea what they are and hard to track. What wires should be going to the positive terminal in order to her to just start and run? Just looking for a starting point. Thanks. |
| dr914@autoatlanta.com |
Sep 23 2019, 08:28 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,245 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
all of the small red wires need to be tightly and cleanly connected to the postitive side of the battery, they go to the relay panel in the engine compartment as well as to the fuse block and the ignition switch.
First thing that will kill a battery is aftermarket devices attached to the car like radios and amplifiers. Next you can look at a bad diode in the alternator. Putting a test light between the positive terminal and battery post, noting that it is glowing brightly and then pulling the voltage regulator and or one fuse at a time will narrow down the drain when you see the test light go off quote name='surfdogskier' date='Sep 23 2019, 06:52 AM' post='2749502'] Hey guys, When I got my car, it was a mess. Wires everywhere. Something is killing my battery after a couple of days. I have numerous wires going to my positive terminal. I have no idea what they are and hard to track. What wires should be going to the positive terminal in order to her to just start and run? Just looking for a starting point. Thanks. [/quote] |
Lo-Fi Version | Time is now: 25th September 2026 - 10:40 PM |
