Temperature Head Sensor, Replacement Advice Needed |
JawjaPorsche |
Sep 25 2019, 02:59 AM
I suspect my temperature head sensor is the reason my 914 runs a little rough the first couple miles.
I know where it is on my 1.7. Do need to remove the tin to replace or can it be removed through the tin hole? I know a deep socket is needed to stuff the wire in. Any advice would be greatly appreciated. |
BeatNavy |
Sep 25 2019, 06:04 AM
You can leave the tin on and use a deep socket. Some people, including me, cut a notch in a 3 inch extension to thread the wire and lead through the socket. Others are able to just get the lead all stuffed inside the socket.
Just be careful putting a new one in. You don't want to strip those threads. |
Mikey914 |
Sep 25 2019, 09:37 AM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Deep socket
Got them here if you need one https://shop.914rubber.com/Cylinder-Head-Te...m?categoryId=-1 Attached thumbnail(s) |
dr914@autoatlanta.com |
Sep 25 2019, 10:37 AM
914 Guru Group: Members Posts: 7,872 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
and smack the top of the head of the sensor to unfreeze the threads before turning it out Notching the extension is the trick I learned long long ago
Triaddave |
Sep 25 2019, 10:39 AM
Member Group: Members Posts: 244 Joined: 31-December 03 From: olympia,wa Member No.: 1,478 |
I use a deep socket I bought at Harbor freight, I drilled a hole in the side of the (cheap throw- away) socket for the wire. I use it quite often.
Lo-Fi Version | Time is now: 23rd May 2024 - 06:05 PM |
