| EJP914 |
Sep 26 2019, 10:09 AM
Member ![]() ![]() Group: Members Posts: 284 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 |
I own a 74 1.8 with a single Weber carb. I know its not the best set up but it's what I own. What is the best fuel pump to use for these carbs? I have an electric Facet pump on the car now. Car bogs down in the corners and will not idle or run smoothly when it gets hot. Plugs look good - fluffy tan/brown color. Mechanic said maybe pump is going bad, fuel starvation coming out of corners or when hot. Looking for opinions before I do the start to replace parts and maybe that will cure the problem. Thanks.
Ed |
| michael7810 |
Sep 26 2019, 10:39 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,082 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region
Might be good to replace the filter and check fuel pressure first. You should get 2-3 psi while with the engine running. Also, does your system have a separate regulator and/or return line?
| Tbrown4x4 |
Sep 26 2019, 10:47 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 708 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None
I always hated the noise the facets make. If you have to replace the pump, the CB performance rotary pump has been good to me. It hums a bit, but I haven't tried to insulate it and I think the body is touching the trunk wall.
| brant |
Sep 26 2019, 11:14 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,159 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
any low volume carb pump will work.
Facet will work fine... they make an annoying rattly noise so most prefer the rotary pumps instead. cleaning the fuel filter is a good recommendation.... but the single carb intake runners are likely going to still cause the same stumble and hesitations you are experiencing. you didn't mention which distributor changing intakes to a dual carb set up with the correct carb distributor will likely be the solution you are seeking. |
| dr914@autoatlanta.com |
Sep 26 2019, 11:53 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,232 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
the facet is good for the money and should be isolated with rubber mounts and mounted low very dependable
| SirAndy |
Sep 26 2019, 12:30 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,458 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I always hated the noise the facets make. If you have to replace the pump, the CB performance rotary pump has been good to me. It hums a bit, but I haven't tried to insulate it and I think the body is touching the trunk wall. (IMG:style_emoticons/default/agree.gif) https://www.cbperformance.com/product-p/3193.htm (IMG:http://www.914world.com/bbs2/uploads_offsite/www.cbperformance.com-179-1569522654.1.jpg) |
| porschetub |
Sep 26 2019, 01:48 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,040 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Certainly worth checking the filter,also take the top off the carb and check the float level , personally not a fan of these pumps but they do rattle away for a long time so maybe it is just filter or float level.
I think these carbs also have a fine plastic filter on the inlet,most don't clean them or know they are there. Good luck. |
| EJP914 |
Sep 26 2019, 02:18 PM
Many thanks to all for the replies. I had figured to start with the filter. Hasn't been changed for years.
Yeah the Facet makes an annoying sound. I've gotten used to it. In response to the one question asked, no I do not have a return line running back to the tank (if that is what was being asked?) nor do I have a pressure regulator installed. Always heard you did not need much fuel pressure for a single carb to work and I thought t he Facet would do the job. The fuel pump is located where the factory FI pump was installed. I will check the carb further as suggested by our friend in New Zealand. Didn't know those things existed. Thanks again. Ed |
Lo-Fi Version | Time is now: 14th March 2026 - 06:00 PM |
