brcacti |
1974 914 1.8 ![]() ![]() ![]() Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region ![]() |
Steering wheel main nut socket size, does anyone know off hand the size?, I need to buy this socket, don't have one that big. My 19mm is not even close, guessing 24-27mm
Thanks if you know. |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,032 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,963 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
When you remove the wheel, unscrew the nut all but a couple threads, pull the wheel loose. Keeping the nut on with a couple threads will prevent you from catching the wheel in your face if it lets go quickly.
brcacti |
Thanks to all that replied with information, it helps as I am not a mechanic but do many small things on the car. I am going to put the stock wheel back on for two reasons, to keep it stock and to see the speedometer better. (IMG:style_emoticons/default/smile.gif)
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,339 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
1 -1/16" iirc
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,187 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
infraredcalvin |
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,651 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California ![]() ![]() |
When you remove the wheel, unscrew the nut all but a couple threads, pull the wheel loose. Keeping the nut on with a couple threads will prevent you from catching the wheel in your face if it lets go quickly. BTDT (IMG:style_emoticons/default/av-943.gif) |
When you remove the wheel, unscrew the nut all but a couple threads, pull the wheel loose. Keeping the nut on with a couple threads will prevent you from catching the wheel in your face if it lets go quickly. BTDT (IMG:style_emoticons/default/av-943.gif) Lots of people have including one of our young shop guys who tried to pretend it didn't happen. Another tip. Don't use the steering lock for leverage to torque against. The best way to remove a tight nut is with a rattle gun. |
brcacti |
Mepstein.............thanks, I did hear that before but good to remind in case some don't know.
Lo-Fi Version | Time is now: 11th July 2025 - 12:15 AM |
