Getting key duplicates, Mystery Key Blank |
tvdinnerbythepool |
Sep 30 2019, 07:35 AM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
Hey guys,
Forgive me if this is stupid but... Need to get a copy of my keys made...Is this an Ace Hardware job? Do I need to source blanks before hand or are they avail at local hardware stores? Thanks! -Rob |
ClayPerrine |
Sep 30 2019, 07:41 AM
Life's been good to me so far..... Group: Admin Posts: 15,435 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Hey guys, Forgive me if this is stupid but... Need to get a copy of my keys made...Is this an Ace Hardware job? Do I need to source blanks before hand or are they avail at local hardware stores? Thanks! -Rob Most good locksmiths will have metal key blanks for 914s. If you want genuine Porsche key blanks, you can contact one of our suppliers. I buy them from Zim's. (For full disclosure, I used to work there). Considering the age of the cars, and the wear on the keys, I suggest taking the ignition lock out of the car and taking it to a locksmith to have a key cut from the lock. That way you get a nice, sharp key. Then have them cut a steel blank, but only on one side of the key. That one will become your template for making new keys. Because it is only cut on one side, it can't be used in the car, so it will never wear. If you get all your new keys cut from it, you won't carry over the wear of the old key. Good luck. |
dr914@autoatlanta.com |
Sep 30 2019, 07:50 AM
914 Guru Group: Members Posts: 7,832 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
anyone with a key cutter can cut a 914 key if they take their time, it is having the blanks that is the problem. Best to call, like Clay said, a locksmith and ask if they have the blank first.
We cut the keys here all of the time and have the aftermarket blanks along with the factory ones, but are hesitant to copy an aftermarket cut key onto an original blank as often key cutters in the past have done a hap hazard job, the keys are cut down too far or parts not cut precisely enough and copying this kind of a key RUINS an expensive factory blank The other thing to do is to have Porsche do one for you from the vehicle id number, Yes they can do it back to 72 models, if you press them, but since so many 914 keys and locks have been switched by now, you may get an expensive key that does not work Finally a GOOD locksmith looks at the old key, counts the "bump" height (corresponding to the lock wafers) puts those numbers, 1-4 into his machine and cuts a PERFECT duplicate of the original Hey guys, Forgive me if this is stupid but... Need to get a copy of my keys made...Is this an Ace Hardware job? Do I need to source blanks before hand or are they avail at local hardware stores? Thanks! -Rob |
tvdinnerbythepool |
Jan 22 2020, 07:42 AM
Hey Guys,
Finally getting around to ordering keys to make duplicates. This is my ignition key (different from the door which is the regular 914 key blank) Can't seem to find the correct blank to match this ignition key though. Anyone know if this is from a different model that someone swapped in at some point? |
tvdinnerbythepool |
Jan 22 2020, 07:43 AM
ClayPerrine |
Jan 22 2020, 09:39 AM
That is like no other 914 key I have ever seen. Maybe somebody fitted a later model ignition lock to your car?
Good luck with it. |
tvdinnerbythepool |
Jan 22 2020, 11:11 AM
That is like no other 914 key I have ever seen. Maybe somebody fitted a later model ignition lock to your car? Good luck with it. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) of course they did....add it to the list of things they (prior owner) "modded" on the car |
Jan 22 2020, 11:13 AM
914-6 GT in waiting Group: Members Posts: 19,254 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
At least now you have the chance to fix it back to one key. (IMG:style_emoticons/default/beerchug.gif)
ClayPerrine |
Jan 22 2020, 12:26 PM
Just source a replacement column from a parts car of the same year and swap it out.
Then you can have the ignition lock keyed to match the door key. |
TonyA |
Jan 22 2020, 12:39 PM
Nachmal Group: Members Posts: 460 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States |
Was the red key just for the glove box? Or did it operate the doors and the ignition switch also?
ClayPerrine |
Jan 22 2020, 12:52 PM
Was the red key just for the glove box? Or did it operate the doors and the ignition switch also? It was the "valet key". It was setup from the factory to only open the doors and turn on the ignition. I actually use a red key for everything on my six conversion. I use a black key for the factory six. That way I can tell them apart when they are on the same key ring. |
bbrock |
Jan 22 2020, 12:54 PM
That is like no other 914 key I have ever seen. Maybe somebody fitted a later model ignition lock to your car? Good luck with it. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) of course they did....add it to the list of things they (prior owner) "modded" on the car I wouldn't be too harsh on this one. It's a very common thing. The ignition key tumblers became NLA a long time ago so lots of owners swapped in whatever tumbler (usually VW) would work. Was the red key just for the glove box? Or did it operate the doors and the ignition switch also? The red key is a valet key which will operate doors and ignition but NOT glove box or either trunk. That is... if the locks are all still keyed as original. There is a special valet wafer that is supposed to replace a random wafer in the glove box and trunk locks which prevents the red key from opening them. My first 914 only came with a red key and I didn't figure out why my trunk and glove box locks wouldn't work until years after I sold that car. |
rhodyguy |
Jan 22 2020, 01:07 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,071 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
A skilled locksmith can 'read' the ignition itself. They use a blank of very soft material that leaves witness marks when turned in the ignition. I watched when a mobile locksmith was at my house after the 914 was stolen. It came home without the key. When I had the Subaru I gave up on the hardware store after 3 tries because they could not cut a key that worked. First time I didn't check it before I went home. 2nd and 3rd times I tried the new key(s. New blank every time) in the parking lot. Surrendered and went to a locksmith. It took about 15 minutes to get a couple of functional keys.
Jan 22 2020, 05:20 PM
tvdinnerbythepool |
Jan 22 2020, 07:04 PM
Thanks EVERYONE as always for the input. I know that a rekey of the whole car is in order at some point. For now I'll try and source this key to get me by.
(IMG:style_emoticons/default/beerchug.gif) |
Mikey914 |
Jan 22 2020, 07:18 PM
The rubber man Group: Members Posts: 12,649 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
In stock
https://900designs-container.zoeysite.com/b...che-914-and-911 Any locksmith should be able to duplicate. I'll PM ya with a contact. Attached image(s) |
Lo-Fi Version | Time is now: 4th May 2024 - 01:18 AM |
