Targa rubber on body - top of roll bar, Not sure what the part is called... |
FlacaProductions |
Oct 9 2019, 07:36 PM
Senior Member Group: Members Posts: 1,570 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
ConeDodger |
Oct 9 2019, 10:16 PM
Apex killer! Group: Members Posts: 23,576 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Steve |
Oct 9 2019, 10:28 PM
914 Guru Group: Members Posts: 5,575 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Could remove it and try to repair it. Looks like someone tried to pry it off
raynekat |
Advanced Member Group: Members Posts: 2,157 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Don't believe that will stick back down easily.
Looks like your vinyl and underlying foam as all been distorted in the area? You might need a replacement or at least a good restoration of that trim piece for it to look nice. |
Mikey914 |
Oct 9 2019, 11:47 PM
The rubber man Group: Members Posts: 12,652 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The foam has lifted not much you can do. I have the AA ones in stock and as Rob noted we are working on the correct textured ones. We just have one very big project that we will be dropping in about a week. As soon as it's wrapped up we can do these.
Mark |
FlacaProductions |
Oct 10 2019, 08:55 AM
Thanks all - I'll live with it for now - other things on the list and I'll keep an eye on the progress from 914Rubber - thanks!
dr914@autoatlanta.com |
Oct 10 2019, 11:31 AM
914 Guru Group: Members Posts: 7,833 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
you could wet it and then clamp it back into shape. no reason to purchase another one. The ones we make are for people with heavily cracked ones who do not want to pay just dashes 500 plus to redo theirs. (we have their reskinned ones here and although they do a good job, our reproductions are certainly acceptable and inexpensive. We are almost finished with our front hardtop bolsters between the latches and are doing the piece under the visors
FlacaProductions |
Oct 10 2019, 11:49 AM
Wetting it - interesting but I understand - thank you!
ConeDodger |
Oct 10 2019, 03:15 PM
My friend who owns an upholstery shop, put clear silicone in the separation and then wrapped the area with tape. The result is the separation was reduced by about half. If you know my car, you know that is not acceptable. When these come from Mark, there is no way he’ll make the R&D back. This project has been one of his greatest adventures.
Lo-Fi Version | Time is now: 5th May 2024 - 03:23 PM |
