cheap cheap cheap 914 visor set, since there has been so much discussion |
dr914@autoatlanta.com |
Oct 10 2019, 12:29 PM
914 Guru Group: Members Posts: 7,840 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Since there has been so much discussion about 914 sun visors I thought I would chime in. Foe a while now, we have been selling our factory look set for 275 new complete with clips and pass mirror and drivers map pocket. They will pass the concours inspection.
However we also sold a cheap alternative. Map pocket but no mirror, heat seamed but not a matching grain to the original. Come with left and right clip, but no center clip (914 rubber makes a nice center clip if you need one. But here it is: The price for two is only 99.50. If you have no visors and a driver 914 these are for you. If you have a concours car, or an original nice nice car they are NOT for you. Look at these yourself and decide |
jvmarino |
Oct 16 2019, 07:09 PM
Member Group: Members Posts: 80 Joined: 22-March 09 From: Baltimore Member No.: 10,188 Region Association: None |
So I just received my pair and am pretty happy with the set, especially at the price point. Two items to note. As previously mentioned, the inner holes need to be made by installer, but it is pretty easy to do. The 2nd observation is the outer brackets are installed the wrong way, so they need to be swapped. Even the picture above has them the wrong way. Again, not a big deal, just took me by surprise.
Jim |
DickSteinkamp |
Oct 16 2019, 07:40 PM
Senior Member Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
So I just received my pair and am pretty happy with the set, especially at the price point. Two items to note. As previously mentioned, the inner holes need to be made by installer, but it is pretty easy to do. The 2nd observation is the outer brackets are installed the wrong way, so they need to be swapped. Even the picture above has them the wrong way. Again, not a big deal, just took me by surprise. Jim @jvmarino How did you find the right spot to make the hole for the center support? How did you make the hole? Thanks |
jvmarino |
Oct 16 2019, 09:07 PM
So I just received my pair and am pretty happy with the set, especially at the price point. Two items to note. As previously mentioned, the inner holes need to be made by installer, but it is pretty easy to do. The 2nd observation is the outer brackets are installed the wrong way, so they need to be swapped. Even the picture above has them the wrong way. Again, not a big deal, just took me by surprise. Jim @jvmarino How did you find the right spot to make the hole for the center support? How did you make the hole? Thanks It is just a basic friction fit in a clip tensioned by the exterior screw, so I just cut a small opening with a sharp razor blade and then pushed the metal post into the clip inside the visor. Hole location is pretty much the same as the post used for the outer brackets. |
Lo-Fi Version | Time is now: 9th May 2024 - 02:51 AM |
