2 Pages V < 1 2
> cheap cheap cheap 914 visor set, since there has been so much discussion
jvmarino
post Oct 16 2019, 07:09 PM
Post #21
So I just received my pair and am pretty happy with the set, especially at the price point. Two items to note. As previously mentioned, the inner holes need to be made by installer, but it is pretty easy to do. The 2nd observation is the outer brackets are installed the wrong way, so they need to be swapped. Even the picture above has them the wrong way. Again, not a big deal, just took me by surprise.
Jim
DickSteinkamp
post Oct 16 2019, 07:40 PM
Post #22
QUOTE(jvmarino @ Oct 16 2019, 06:09 PM) *
Jim
@jvmarino
How did you find the right spot to make the hole for the center support? How did you make the hole?
Thanks
brcacti
post Oct 16 2019, 07:47 PM
Post #23
1974 914 1.8
They look very cool, I like them
jvmarino
post Oct 16 2019, 09:07 PM
Post #24
QUOTE(DickSteinkamp @ Oct 16 2019, 09:40 PM) *
Jim
@jvmarino
Thanks
It is just a basic friction fit in a clip tensioned by the exterior screw, so I just cut a small opening with a sharp razor blade and then pushed the metal post into the clip inside the visor. Hole location is pretty much the same as the post used for the outer brackets.
2 Pages V < 1 2
- Lo-Fi Version Time is now: 12th July 2025 - 07:19 AM
