FS: date 1974 Porsche 914 steering wheel SOLD |
ETMracing |
Oct 11 2019, 07:06 PM
Newbie Group: Members Posts: 37 Joined: 22-August 13 From: frederick md Member No.: 16,288 Region Association: MidAtlantic Region |
ETMracing |
Oct 11 2019, 07:08 PM
ETMracing |
Oct 11 2019, 07:09 PM
Chi-town |
Oct 12 2019, 01:28 AM
Wrong hub for a 911, they need the non-stepped splines in the rear and it would have to be drilled for the 911 cancel ring.
ClayPerrine |
Oct 12 2019, 06:49 AM
Life's been good to me so far..... Group: Admin Posts: 15,459 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Wrong hub for a 911, they need the non-stepped splines in the rear and it would have to be drilled for the 911 cancel ring. Nope. Not true. Well, partially.... All of the 914 wheels and all of the early 911 wheels have the same spline count. They will all interchange. Granted the wheel outer diameters are different, the 914 uses a 380mm wheel, the 911 uses either a 400 or 430mm wheel. The 911 guys want the early 914-6 wheels, as they were used on the 911 RSR. They could use the 4 cylinder wheels, but they keep spreading the false information that they are differently splined. This was hashed out in an old thread here: http://www.914world.com/bbs2/index.php?sho...77498&st=20 You do have to drill a 74 wheel for the 911 cancel cam. That involves drilling and tapping two holes, and cutting a countersync for them. But the wheel itself will bolt on. We have a factory six, and I had the wheel from my wife's 74 bolted onto it. It was temporary, so I didn't drill the holes for the cancel cam. But everything else worked perfectly. |
Chi-town |
Oct 12 2019, 11:09 AM
There is a step in the splines on the later 914 wheels. Will it fit? yes. Is it right? No.
The last -6's use the VW column so the stepped spline is correct for them. Some of the 911 guys aren't informed on the 380mm wheels so I was just putting the info it there. |
PCA7GGR |
Oct 12 2019, 12:29 PM
Member Group: Members Posts: 251 Joined: 3-October 03 From: Dublin, CA Member No.: 1,219 |
Once installed with horned, will it look and steering the same? YES
Lo-Fi Version | Time is now: 14th May 2024 - 01:24 AM |
