Non 914 Question ....still med engine, Boxster I know a few of you guys have them... |
oldschool |
Oct 12 2019, 09:20 PM
Advanced Member Group: Members Posts: 3,362 Joined: 29-October 08 From: P-town Member No.: 9,705 Region Association: Southern California |
I have notice that if I don't drive the boxster for a few weeks it's hard to turn over?
..Need to put on the charger, any one notice this. (IMG:style_emoticons/default/biggrin.gif) |
Mark Henry |
Oct 13 2019, 04:01 PM
I only have experience with 996/7 but it's common issues. The battery drain from alarm, etc., plus the starter wire (at the engine) corrode at the funky connectors causing a voltage drop and the starter is weak at best.
JOEPROPER |
Oct 13 2019, 05:33 PM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
I only have experience with 996/7 but it's common issues. The battery drain from alarm, etc., plus the starter wire (at the engine) corrode at the funky connectors causing a voltage drop and the starter is weak at best. Hmm... this is good to know. I have a similar problem with my 996. I'll have to check it out. Thanks. (IMG:style_emoticons/default/flag.gif) |
Mark Henry |
Oct 13 2019, 08:04 PM
I only have experience with 996/7 but it's common issues. The battery drain from alarm, etc., plus the starter wire (at the engine) corrode at the funky connectors causing a voltage drop and the starter is weak at best. Hmm... this is good to know. I have a similar problem with my 996. I'll have to check it out. Thanks. (IMG:style_emoticons/default/flag.gif) Buy a new cable from porsche, PITA job, best to remove the AC pump (don't undo the lines) and alternator. When you're done the job cut the old cable sheath back a bit at the starter connector, you should be able to see the corrosion. |
Lo-Fi Version | Time is now: 15th May 2024 - 12:11 PM |
