Fuel injector question for the experts please |
Creamsicle New Zealand |
Oct 14 2019, 01:27 PM
Member Group: Members Posts: 83 Joined: 5-February 15 From: New Zealand Member No.: 18,403 Region Association: Australia and New Zealand |
Hi all I need help please with regards to which fuel injector is correct for my engine. I have a 2.0lt Creamsicle (1974) one of my injectors is leaking and decided to get a new one in fact I will get two just in case one fails in the future. I have the option of buying two NOS from this forum. 1 is part # 0 280 150 019 for 73-74 engine the other is part # 0 280 150 038 for 75-76 engine. The question is can I use the injector for 75-76 on my 74 engine?
Thanks in advance for any help. Steve |
JeffBowlsby |
Oct 14 2019, 03:02 PM
914 Wiring Harnesses Group: Members Posts: 8,515 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Same same in terms of performance. Its not documented anywhere, but its my understanding that the later version has a hardened pintle due to the higher heat generated by the later engines for emissions purposes.
Did you know the 75-76 cars had what the factory literature terms "thermal reactors"? They are the J-tubes bolted to the heads, supposedly intended to burn off unburnt fuel. |
Lo-Fi Version | Time is now: 24th May 2024 - 09:58 AM |
