GB CLOSES in a few hours 31st for late window scrapers with new fuzzey (non-sucking), Basically buy the aluminum strips at a discount seals are FREE or just buy the seals on GB |
ConeDodger |
Oct 19 2019, 09:57 AM
Apex killer! Group: Members Posts: 23,572 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I have your earlier effort and frankly, don’t recall a problem with them - ever. But if you've made something better, I suppose I’d better try it! (IMG:style_emoticons/default/evilgrin.gif)
maf914 |
Oct 19 2019, 02:04 PM
I am in for at least one set. Thanks, Mark, as usual.
Lucky9146 |
Oct 19 2019, 08:29 PM
Always Wanted A Bigger Go Cart Group: Members Posts: 1,607 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California |
I'm in for a set please! Funny how you don't know you need something until a post like this comes around and you go and look at your current scrapers and see they are so tight against the glass. Should help things a lot. Thanks!
(IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/white914.jpg) |
jmitro |
Oct 20 2019, 02:16 PM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
ill take a set (one pair for one car I assume)
scallyk9 |
Oct 20 2019, 02:33 PM
Member Group: Members Posts: 318 Joined: 16-October 16 From: Port Orchard, WA, USA Member No.: 20,499 Region Association: Pacific Northwest |
I'd also like to buy a set.
Steve |
Oct 20 2019, 02:47 PM
914 Guru Group: Members Posts: 5,570 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I’m in
Andyrew |
Oct 20 2019, 03:19 PM
In
TitanMZ3 |
Oct 20 2019, 04:23 PM
Newbie Group: Members Posts: 6 Joined: 19-September 19 From: Virginia, USA Member No.: 23,479 Region Association: MidAtlantic Region |
I'll go in on a set
bobboinski |
Oct 20 2019, 06:47 PM
Member Group: Members Posts: 198 Joined: 23-April 16 From: Petaluma Member No.: 19,929 Region Association: Northern California |
One set please.
Mikey914 |
Oct 21 2019, 08:49 AM
The rubber man Group: Members Posts: 12,646 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Will be sending out codes late this afternoon.
markhoward |
Oct 21 2019, 09:15 AM
Member Group: Members Posts: 375 Joined: 5-March 17 From: Lafayette, CA Member No.: 20,897 Region Association: Northern California |
im in for a set
914outlaw |
Oct 21 2019, 09:34 PM
Dave Group: Members Posts: 198 Joined: 2-June 10 From: Central, NJ Member No.: 11,800 Region Association: North East States |
I’m in for 5 sets.
Mikey914 |
Oct 21 2019, 11:43 PM
PMs sent to all so far. Plan to hold this open til the end of the Month
THANKS ALL! |
djway |
Oct 22 2019, 02:29 AM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
Tried to order several sets but it would only apply discount for one set.
What is the work around. Thanks |
Mikey914 |
Oct 22 2019, 05:06 AM
DucRS |
Oct 22 2019, 10:11 AM
Member Group: Members Posts: 105 Joined: 29-May 19 From: Riverbank CA Member No.: 23,173 Region Association: Central California |
There should be a “warning” label before one enters the 914 Rubber store. What started out as a $5 savings on fuzzy wuzzzy item turned out to be a $400 purchase of rubberized items. (IMG:style_emoticons/default/unsure.gif)
(IMG:style_emoticons/default/biggrin.gif) |
Mikey914 |
Oct 22 2019, 10:27 AM
DAX |
Oct 22 2019, 12:20 PM
Newbie Group: Members Posts: 11 Joined: 5-April 10 From: CALIFORNIA Member No.: 11,564 Region Association: Central California |
I am in if it is not late
dax |
Literati914 |
Oct 22 2019, 12:52 PM
Senior Member Group: Members Posts: 1,441 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
The early "correct" version was made specifically for the 914 ..... The early do not grab the window. At some point in 73 they decided to superseded the part with the 911 one they already made as it "worked" .. That's the early / late deal. So just to make sure I understand this statement - If you have an early 914, you would have actually gotten a later model window scraper if ordering at set (from anyone other than 914rubber) after porsche had supersede the original items. Which confirms that the late scraper seals work on the early cars. Then what's the aluminum track for? I think that's what's throw me. |
Mikey914 |
Oct 22 2019, 01:46 PM
We do have the correct "Early" scraper seal you will see below -
https://900designs-container.zoeysite.com/e...craper-seal-set Also put on sale for you It was superseded with the part we are doing on the GB. As part of the GB you have the option to add in the tracks that hold them at a price that makes the scrapers The aluminum track holds the rubber outer scrapers and the inner fuzzey against the window (see below). The problem with the aluminum tracks is many DAPO's have used screw drivers to open up the channel to insert the rubber. The rubber can be stretched them pushed in with some lubrication.... once again lubrication is your friend. Attached thumbnail(s) Attached image(s) |
Lo-Fi Version | Time is now: 30th April 2024 - 10:51 AM |
