Engine dies but restarts after 2 minutes, Help please! Only a couple weeks left to drive in MN |
SteveL |
Oct 16 2019, 02:27 PM
Senior Member Group: Members Posts: 658 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None |
74 1.8 with L-Jet. Starts and runs perfect for a while.
After driving or running for anywhere between 5-20 minutes, the engine loses all power, but still sounds like it is running for about 20 seconds, then dies completely. While it still sounds like it is running, I can put the pedal to the floor and it makes no difference. If I try to start it right away, it will not start. Every time so far, after I wait a couple of minutes it will restart and run like nothing happened for a few more minutes, then die again. I have replaced the dual relay with a known good. I think the next suspect is the fuel pump. I see a T fitting in the driver side fuel rail that is plugged by a bolt. Is that where I would connect a fuel pressure test gauge? Is that the best next step to check? |
Mark Henry |
Oct 16 2019, 06:30 PM
(IMG:style_emoticons/default/agree.gif) Check your fuel pressure.
I tape a pressure gauge to my back window, so I can see it out of my RV mirror and watch it for when the issue happens. 60 psi gauge (HF, etc), length of 5/16" FI hose, 2 FI clamps and yes the one injection rail has a test port. Don't lose the little screw, once the job is done I take it back off. I had a 914 that would collapse the under tank large fuel hose and die after 20 minutes highway driving. Found and fixed it with a gauge reading. |
Lo-Fi Version | Time is now: 18th May 2024 - 03:03 PM |
