Engine dies but restarts after 2 minutes, Help please! Only a couple weeks left to drive in MN |
SteveL |
Oct 16 2019, 02:27 PM
Senior Member Group: Members Posts: 658 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None |
74 1.8 with L-Jet. Starts and runs perfect for a while.
After driving or running for anywhere between 5-20 minutes, the engine loses all power, but still sounds like it is running for about 20 seconds, then dies completely. While it still sounds like it is running, I can put the pedal to the floor and it makes no difference. If I try to start it right away, it will not start. Every time so far, after I wait a couple of minutes it will restart and run like nothing happened for a few more minutes, then die again. I have replaced the dual relay with a known good. I think the next suspect is the fuel pump. I see a T fitting in the driver side fuel rail that is plugged by a bolt. Is that where I would connect a fuel pressure test gauge? Is that the best next step to check? |
jcd914 |
Oct 16 2019, 03:24 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
I think the next suspect is the fuel pump. I see a T fitting in the driver side fuel rail that is plugged by a bolt. Is that where I would connect a fuel pressure test gauge? Is that the best next step to check? Yes that is where you would hook up a fuel pressure gauge. Suspecting the Fuel pump is a good next step. You can also hook up a test light to the fuel pump circuit to see if the pump is getting power or not. If I am remembering the L-jet system correctly, with the key on but engine off, pushing the flap open in the AFM should make the fuel pump run. You can check for power and pressure in a single test. Jim |
dr914@autoatlanta.com |
Oct 16 2019, 03:27 PM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
excellent advice, the only other thing is if the flap is sticking it would die then the flap would unstick and one could just drive off, especially if it sort of runs like it is running out of gas, it would be sort of flooding out
porschetub |
Oct 19 2019, 08:42 PM
Advanced Member Group: Members Posts: 4,699 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
excellent advice, the only other thing is if the flap is sticking it would die then the flap would unstick and one could just drive off, especially if it sort of runs like it is running out of gas, it would be sort of flooding out I think the next suspect is the fuel pump. I see a T fitting in the driver side fuel rail that is plugged by a bolt. Is that where I would connect a fuel pressure test gauge? Is that the best next step to check? Yes that is where you would hook up a fuel pressure gauge. Suspecting the Fuel pump is a good next step. You can also hook up a test light to the fuel pump circuit to see if the pump is getting power or not. If I am remembering the L-jet system correctly, with the key on but engine off, pushing the flap open in the AFM should make the fuel pump run. You can check for power and pressure in a single test. Jim (IMG:style_emoticons/default/agree.gif) with the George ,the flap can stick and leave you with no feedback to fuel requirement @ a given throttle position ,it needs to be free moving and snap closed quickly on the quadrant spring,posted recently about this and think the backfire story is a myth,mine has a vent disc and is sticking,the air flap is not a part easily bent,IMO its just wear as the air gate rubs on the lower cover plate when worn. A guy on the bird has opened one up and proved that...good reading. By all means check fuel pump function and check for a bad coil that is breaking down also. |
SteveL |
Oct 19 2019, 10:16 PM
[/quote]
(IMG:style_emoticons/default/agree.gif) with the George ,the flap can stick and leave you with no feedback to fuel requirement @ a given throttle position ,it needs to be free moving and snap closed quickly on the quadrant spring,posted recently about this and think the backfire story is a myth,mine has a vent disc and is sticking,the air flap is not a part easily bent,IMO its just wear as the air gate rubs on the lower cover plate when worn. A guy on the bird has opened one up and proved that...good reading. By all means check fuel pump function and check for a bad coil that is breaking down also. [/quote] Thank you for the guidance, it is greatly appreciated. When it dies, I will be driving along at 1-2k rpm, so the flap would not be closed. And, even if the flap was closed, the car would still idle, correct? I hadn't considered the coil. Do coils fail in an intermittent fashion like this? If so, I see RockAuto has an NGK coil for about $15, so easy to just replace in case (or do I need a Bosch blue coil at like $65?). Thanks again. |
potomacmidget |
Oct 20 2019, 12:14 PM
I gotta have more cowbell.... Group: Members Posts: 161 Joined: 27-March 11 From: Maryland Member No.: 12,860 Region Association: North East States |
[quote name='SteveL' date='Oct 20 2019, 12:16 AM' post='2755838']
[/quote] (IMG:style_emoticons/default/agree.gif) with the George ,the flap can stick and leave you with no feedback to fuel requirement @ a given throttle position ,it needs to be free moving and snap closed quickly on the quadrant spring,posted recently about this and think the backfire story is a myth,mine has a vent disc and is sticking,the air flap is not a part easily bent,IMO its just wear as the air gate rubs on the lower cover plate when worn. A guy on the bird has opened one up and proved that...good reading. By all means check fuel pump function and check for a bad coil that is breaking down also. [/quote] Thank you for the guidance, it is greatly appreciated. When it dies, I will be driving along at 1-2k rpm, so the flap would not be closed. And, even if the flap was closed, the car would still idle, correct? I hadn't considered the coil. Do coils fail in an intermittent fashion like this? If so, I see RockAuto has an NGK coil for about $15, so easy to just replace in case (or do I need a Bosch blue coil at like $65?). Thanks again. [/quote] Hi. I experienced a similar issue with my 71 D-JET. Installed new fuel filter, new blue coil , checked timing again (as I had physically pulled the distributor to work on it) and no resolution. Inspected my points and found gap/dwell way off. Gap had slipped and was almost nonexistent. Car would start, run great for 20 minutes and die. I think gap would completely close off with hot dizzy. I reset the points and checked dwell and my issue went away. Of course I should have started at the points.... |
Lo-Fi Version | Time is now: 18th May 2024 - 03:40 PM |
