Engine dies but restarts after 2 minutes, Help please! Only a couple weeks left to drive in MN |
SteveL |
Oct 16 2019, 02:27 PM
Senior Member Group: Members Posts: 658 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None |
74 1.8 with L-Jet. Starts and runs perfect for a while.
After driving or running for anywhere between 5-20 minutes, the engine loses all power, but still sounds like it is running for about 20 seconds, then dies completely. While it still sounds like it is running, I can put the pedal to the floor and it makes no difference. If I try to start it right away, it will not start. Every time so far, after I wait a couple of minutes it will restart and run like nothing happened for a few more minutes, then die again. I have replaced the dual relay with a known good. I think the next suspect is the fuel pump. I see a T fitting in the driver side fuel rail that is plugged by a bolt. Is that where I would connect a fuel pressure test gauge? Is that the best next step to check? |
SteveL |
Oct 22 2019, 11:16 PM
Please educate me about ignition coils.
Did a couple of searches, and there seems to be multiple different part numbers for coils, even for Bosch coils, that are listed for our cars. I must admit that the electrical side is not my strong suit. Will any coil work if it is a certain ohm? What is the "right" coil? Thanks |
Lo-Fi Version | Time is now: 18th May 2024 - 12:50 PM |
