Help--Radio Removal? |
gjames |
Oct 17 2019, 12:57 PM
Newbie Group: Members Posts: 10 Joined: 3-March 13 From: Virginia Member No.: 15,606 Region Association: None |
I am trying to remove the radio in the my 76 914. I believe it is an ALPINE(see Pic). I tried using the blade type keys but it didn't move. Ideas?
Attached thumbnail(s) |
dr914@autoatlanta.com |
Oct 17 2019, 01:07 PM
914 Guru Group: Members Posts: 7,820 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
gjames |
Oct 17 2019, 01:59 PM
I am trying to remove the radio in the my 76 914. I believe it is an ALPINE(see Pic). I tried using the blade type keys but it didn't move. Ideas? is there anything bolted behind the radio? You could look underneath the dash and see I looked but didn't see any additional attachments. |
porschetub |
Oct 17 2019, 02:18 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
There could still be a mounting strap which fits on a stud or bolt into the back of the unit then on to the car body,it would be hard to see,I fitted one to my Blaupunkt because the din mounting frame was loose in the dash.
Make sure the removal keys are indeed the right ones,there are different types from brand to brand (IMG:style_emoticons/default/headbang.gif) ,I have lost the keys before and made my own using thin sheetmetal. |
bbrock |
Oct 17 2019, 03:07 PM
Agree with making sure you have the right keys and also that they are inserted all the way. They have to go in far enough to push the sleeve locking tabs out and can catch on the way in and feel like they are bottomed out when they are not. If that doesn't work, you may have to get under the dash with a head lamp and pry the locking tabs away from the radio body with a screw driver, or better, a plastic pry tool. Once you get the head unit out, you can bend the locking tabs back so to their original position.
gjames |
Oct 18 2019, 07:17 AM
Got it out!!!! Thanks for the responses.
theer |
Oct 18 2019, 07:55 AM
Senior Member Group: Members Posts: 676 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
Please reveal your secrets! So this thread has some value to the next person would finds it.
Lo-Fi Version | Time is now: 27th April 2024 - 03:10 AM |
