Measurement needed, Stud length used on Brads billet hubs |
jim_hoyland |
Oct 17 2019, 04:49 PM
Get that VIN ? Group: Members Posts: 9,273 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I bought the 5 lug Billet hubs from Brad back in the day. I’m seeking the stud length from someone that has installed or worked with them.
I’m going to add spacers and would like to order longer studs before pulling the hubs. Attached image(s) |
yeahmag |
Oct 26 2019, 08:56 PM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
This should be pretty easy to measure out. Grab the calipers and measure the thickness of the boss for the studs. Grab a wheel and measure from the back to the outside "flat" of the wheel. Grab a wheel nut and measure from the outside/top/end of the taper (acorn) to the end of the nut. Add all of them together and give yourself some margine: 5mm-10mm. Add the thickness of a spacer if you run them.
I have a bunch of stock, 45mm studs if you need them. |
yeahmag |
Oct 26 2019, 08:58 PM
Grab one of these while you are at it.
https://www.amazon.com/dp/B07TC297SB/ref=cm...i_P45SDb67383J3 |
jim_hoyland |
Nov 19 2019, 02:03 PM
G
Thanks Aaron. Current studs appear to be around 70mm. Looked at the installers on Amazon;are they used to “pull” the stud through the hub and seat the inner serrated head ? And, what the recommended method to remove the old studs ? Lastly, should hub-centric spacers be used @yeahmag Attached image(s) |
mepstein |
Nov 19 2019, 02:23 PM
914-6 GT in waiting Group: Members Posts: 19,256 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
If you are going to have the hub off the car, a press makes short work of the removal and install. About the same effort as tying your shoes.
yeahmag |
Nov 19 2019, 10:12 PM
Those installers Amazon sells are great. You can use a brass drift and hammer to knock the studs out.
Lisle 22800 Wheel Stud Installer https://www.amazon.com/dp/B000ETUD22/ref=cm...p_XJ5tAItCYQS3b |
jim_hoyland |
Nov 20 2019, 06:28 AM
Those installers Amazon sells are great. You can use a brass drift and hammer to knock the studs out. Lisle 22800 Wheel Stud Installer https://www.amazon.com/dp/B000ETUD22/ref=cm...p_XJ5tAItCYQS3b Ordered ! Thanks for the heads up. I just need to remove one of the front hubs and measure a current stud.....any particular brand recommended ? It's a street car. Attached image(s) |
IronHillRestorations |
Nov 20 2019, 06:34 AM
I. I. R. C. Group: Members Posts: 6,716 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I'd suggest using a steel lug nut with the installer
jim_hoyland |
Nov 20 2019, 09:24 AM
914 Ranch |
Nov 21 2019, 04:25 AM
Team Sharp where the 914 grow wings Group: Members Posts: 1,411 Joined: 29-January 16 From: TheNorth Shore Retreat. Deland Member No.: 19,611 Region Association: South East States |
Alignment should not change, Jim.
jmitro |
Nov 21 2019, 06:53 PM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
Lo-Fi Version | Time is now: 7th May 2024 - 06:24 PM |
