Transmission-throw out bearing?, Not sure !! |
sb914 |
Oct 19 2019, 03:14 PM
Surf Guru Group: Members Posts: 4,307 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
So my car makes a grinding noise under load but if I’m just coasting the “ grinding “
Goes away. We pulled the tranny and Noel noticed the throw-out bearing is spinning With ease and “grinding “ check out the video. Does this look right? I really hope this is the problem. I know I could just replace it but I want to be sure beforehand. I planned on putting in a loner tranny until mine was fixed . Hopefully it’s just the TOB ! Video is in post #2 @Dr Evil |
914Sixer |
Oct 19 2019, 07:54 PM
914 Guru Group: Members Posts: 8,892 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Bearing should be free floating when in gear. Only time it might make noise it when the clutch is engaged.
Mark Henry |
Oct 20 2019, 06:01 AM
Bearing should be free floating when in gear. Only time it might make noise it when the clutch is engaged. (IMG:style_emoticons/default/agree.gif) My bug has a release bearing going bad, I only hear it when I press the clutch pedal. But I say that bearing is pretty well done. BTW never rest your foot on the clutch pedal, it will shorten the life of the bearing big time. Also it's important that you have 1/2"-3/4" free play on the pedal so the bearing releases fully. |
Lo-Fi Version | Time is now: 25th May 2024 - 07:08 AM |
