Using a bit of grease to hold the first gear assembly in place when the nosecone is removed? |
Tdskip |
Oct 23 2019, 09:32 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
I need to pull the transmission nosecone assembly off the Arizona car and it was suggested to me that putting a little bit of grease on the first gear assembly would make it easier to reinstall everything because it won’t slide around in the process.
So long as I don’t go crazy with the amount, any issues with this approach? |
ndfrigi |
Oct 23 2019, 09:41 PM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
oooops deleted wrong suggestion.
Tdskip |
Oct 23 2019, 09:50 PM
Dr Evil |
Oct 24 2019, 01:50 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
All good. Makes you younger and stronger as well!
Tdskip |
Oct 24 2019, 01:56 PM
Dr Evil |
Oct 24 2019, 06:25 PM
All good. Makes you younger and stronger as well! Most excellent Doc, I shall use a copious amount because I could readily except being younger and stronger. ;-) Thanks! Careful. Too much and your balls will fall off (IMG:style_emoticons/default/ohmy.gif) |
Lo-Fi Version | Time is now: 4th June 2024 - 10:23 AM |
