Tracking the 914 - Happy New Year!, Turning this into a regular thing... |
infraredcalvin |
Oct 24 2019, 06:08 PM
Distracted Member Group: Members Posts: 1,517 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
1st track day in the bag with the new 914, no decent pics yet (there was a photog in attendants, but haven’t seen his pics yet). Car rand great and although running with much newer machinery she was holding her own once her driver brushed off the cobwebs... (IMG:style_emoticons/default/driving.gif)
Since this was essentially her first shakedown I found a number of little things I need to address, one in particular I’m questioning: After a few laps I noticed - mainly on a flat sweeper turn, when entering hard on brakes and trailing off while turning in I’d get a soft groan from my outside wheel (drivers in this case). I’m thinking wheel bearing? I’ve never had one go bad on the front spindle before, so I’ve never heard or felt the slight vibration before. Never really occurred on any other turns.... thoughts? |
infraredcalvin |
May 27 2021, 11:16 AM
@stownsen914 I never answered your question about the carb specs. Sadly I'm a noob as it relates to carbs, which is why I'm so thrown by this. When I did the carb rebuild I was able to figure out the following, but as i go down with the main jet and idle jets, my gut is telling me that everything else is too big...
Weber 46 IDA 3C Idle jet: 50 Main jet: 140 Emulsion Tubes: F7 Air Correction: 170 Choke: 42 Air filters are K&Ns with a flat rain shield type top. Exhaust are equal length 6 headers at 1.625 and a monte 2 in 2 out muffler. |
wndsrfr |
May 27 2021, 07:17 PM
Senior Member Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Air filters are K&Ns with a flat rain shield type top. Exhaust are equal length 6 headers at 1.625 and a monte 2 in 2 out muffler. I'll chime in about the air filters with rain hats....I found that mine only had slightly more than 3/4 inch from the top of the velocity stack to the metal lid. That caused what I think was significant shrouding of the air flow. My solution was to go to the ITG type filters that have only foam above the edge of the stacks so no shrouding will occur...ymmv... |
infraredcalvin |
May 27 2021, 09:04 PM
Air filters are K&Ns with a flat rain shield type top. Exhaust are equal length 6 headers at 1.625 and a monte 2 in 2 out muffler. I'll chime in about the air filters with rain hats....I found that mine only had slightly more than 3/4 inch from the top of the velocity stack to the metal lid. That caused what I think was significant shrouding of the air flow. My solution was to go to the ITG type filters that have only foam above the edge of the stacks so no shrouding will occur...ymmv... Hmmm that did cross my mind, but I see this setup consistently, so I dismissed it...could be why she seems out of breath on the top end... |
Lo-Fi Version | Time is now: 20th May 2024 - 04:40 AM |
