Tracking the 914 - Happy New Year!, Turning this into a regular thing... |
infraredcalvin |
Oct 24 2019, 06:08 PM
Distracted Member Group: Members Posts: 1,511 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
1st track day in the bag with the new 914, no decent pics yet (there was a photog in attendants, but haven’t seen his pics yet). Car rand great and although running with much newer machinery she was holding her own once her driver brushed off the cobwebs... (IMG:style_emoticons/default/driving.gif)
Since this was essentially her first shakedown I found a number of little things I need to address, one in particular I’m questioning: After a few laps I noticed - mainly on a flat sweeper turn, when entering hard on brakes and trailing off while turning in I’d get a soft groan from my outside wheel (drivers in this case). I’m thinking wheel bearing? I’ve never had one go bad on the front spindle before, so I’ve never heard or felt the slight vibration before. Never really occurred on any other turns.... thoughts? |
GregAmy |
Nov 10 2020, 10:32 PM
Advanced Member Group: Members Posts: 2,290 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
No thoughts on the oil pressure. Greater than zero and I'm happy.
Though, high oil pressure would not generally cause VC hoses to pop off. I'd say put it on the trailer and take it to a car wash. Soap it all off with a car wash sprayer, fire it up and see if you have oil pressure. If so, then seek out the oil loss, starting at the heads' oil tubes, then valve covers/gaskets, block vent, oil tower, etc. If you still have oil pressure and no bangy-bangy noises then it doesn't sound fatal. First time this happened the swaged tube itself pulled out of the head (2L engine). Second time was the hose pulling off of the VC fitting (1.7L engine so no head vents). And it was always the outside-of-the-turn head that had the problem (either tube pulling out or hose pulling off the VC) as I suspect the liquid oil was pooling in the top end and the case pressure was blowing it out. Those head fittings are now threaded into the head for the 2L street car, and will be plugged off on the 2L race engine to use threaded VC hoses in the race car. It's always something. (the 1.7L was a temporary/borrowed F Production engine) I got good vibes corresponding with "Dennis" at FAT about a build. Let's see if they come through. |
Lo-Fi Version | Time is now: 9th May 2024 - 11:13 AM |
