Anyone recognize this?, Galley Oil Pressure Relief Valve Disabled |
Superhawk996 |
Oct 27 2019, 11:28 AM
914 Guru Group: Members Posts: 5,884 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
While pulling the oil galley plugs on engine GA004310 I ran into a new curiosity.
This is a copper galley relief plug designed to block off the end of galley pressure relief valve and disable it. It is turned from a soild piece of copper, but, the shaft is hollow and appears to be designed to collapse when the threaded plug is installed. The built in collapse would be necessary for account for case to case tolerances and to ensure a good seal. I'm not convinced this would seal well over time and that it wouldn't end up "settling in" and having some small but constant leakage vs. the OEM spring and piston design. Anybody ever seen this before? Quick Google search didn't turn up a result but maybe I'm not searching it well. Likewise, if anyone has a spare Galley Relief piston, spring, and the steel 12 point end cap, I'll be looking for one. The 12 point end cap stripped while removing this. Someone clearly thought it would take about 180 lb*ft torque to make sure the copper crush washer sealed! |
MichaelB |
Oct 28 2019, 04:55 PM
Newbie Group: Members Posts: 23 Joined: 24-June 12 From: Wisconsin Member No.: 14,598 Region Association: None |
I found one very similar in a 2.0 GA engine I got out of a 1973 914. It was a GA case but had dished bus pistons and hydraulic lifters. I assumed the plug was an adaptor to increase pressure for the lifters. I posted a pic but was a few years ago. I'll see if I can find it.
MichaelB |
Oct 28 2019, 05:01 PM
Found the pic. Sorry about the poor focus.
Mark Henry |
Oct 29 2019, 11:20 AM
I found one very similar in a 2.0 GA engine I got out of a 1973 914. It was a GA case but had dished bus pistons and hydraulic lifters. I assumed the plug was an adaptor to increase pressure for the lifters. I posted a pic but was a few years ago. I'll see if I can find it. Late bus engine cases with factory hydraulic lifters weren't even machined for the lifter relief piston. You can buy the solid conversion part (uses stock relief piston) from EMW. I'd recommend this block off conversion if you do have hydraulic lifters or early LN ceramic lifters. |
Superhawk996 |
Oct 29 2019, 06:19 PM
And the plot thickens.
@MichaelB @Mark Henry Interesting to see the one from MichaelB. No collapse in the shaft. Different supplier? Hmm. I think so since mine has a constant shaft diameter that fits up inside the 12 point plug. My engine GA004310 had the bus pistons too. Not sure what these folks were thinking they were accomplishing by DROPPING the compression ratio. (IMG:style_emoticons/default/chair.gif) |
Lo-Fi Version | Time is now: 4th June 2024 - 04:45 AM |
