While pulling the oil galley plugs on engine GA004310 I ran into a new curiosity.
This is a copper galley relief plug designed to block off the end of galley pressure relief valve and disable it.
It is turned from a soild piece of copper, but, the shaft is hollow and appears to be designed to collapse when the threaded plug is installed. The built in collapse would be necessary for account for case to case tolerances and to ensure a good seal.
I'm not convinced this would seal well over time and that it wouldn't end up "settling in" and having some small but constant leakage vs. the OEM spring and piston design.
Anybody ever seen this before? Quick Google search didn't turn up a result but maybe I'm not searching it well.
Likewise, if anyone has a spare Galley Relief piston, spring, and the steel 12 point end cap, I'll be looking for one.
The 12 point end cap stripped while removing this. Someone clearly thought it would take about 180 lb*ft torque to make sure the copper crush washer sealed!
