Tach wire kills engine |
surfdogskier |
Oct 28 2019, 12:06 PM
Member Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None |
So when I go to start my car, my tach bottoms out max. None of my gauges work. When I hook my tach wire to my coil (black/purple wire), it kills my engine.
I am sure all of this is related to one thing. Suggestions? |
Retroracer |
Oct 28 2019, 12:35 PM
Senior Member Group: Members Posts: 614 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
Unplug the tach wire at the gauge end and check for shorts to chassis. The symptoms you describe would be similar to what you are seeing?
- Tony |
ClayPerrine |
Oct 28 2019, 12:50 PM
Life's been good to me so far..... Group: Admin Posts: 15,490 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
That also makes a great anti-theft device. Just put a tap on the black/purple wire off the back of the tach, run it through a switch and ground the other side of the switch.
It won't start unless you know about the switch. |
surfdogskier |
Oct 28 2019, 02:03 PM
That also makes a great anti-theft device. Just put a tap on the black/purple wire off the back of the tach, run it through a switch and ground the other side of the switch. It won't start unless you know about the switch. That's a good point. There is something under my dash that is like dials switch that doesn't have a knob on it. It very well could be a kill switch someone put on. It is definitely not factory. I will post back once I am able to get under there. |
Oct 28 2019, 02:24 PM
Resident German Group: Admin Posts: 41,662 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
There is something under my dash that is like dials switch that doesn't have a knob on it. It very well could be a kill switch someone put on. It is definitely not factory. I will post back once I am able to get under there. Sounds like the odometer reset, in which case it is factory ... (IMG:style_emoticons/default/smile.gif) |
dr914@autoatlanta.com |
Oct 28 2019, 02:36 PM
914 Guru Group: Members Posts: 7,875 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Beebo Kanelle |
Oct 28 2019, 09:31 PM
Member Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region |
Check your wiring connections again - make sure the tach is not wired backwards
Spoke |
Oct 29 2019, 05:38 AM
Jerry Group: Members Posts: 6,986 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I had the same issue once. Turned out the wire from the ignition coil to the relay board was shorting to ground. Ran a new wire from the could to the relay board and all was fine.
Try disconnecting the wire at the tach and see if the engine runs. |
Lo-Fi Version | Time is now: 29th May 2024 - 03:35 AM |
